TPS voltage
Old Oct 24, 2009 | 02:01 PM
russ2169's Avatar
Default TPS voltage
Bad idle have narrowed it down to TPS. According to the Hanes manual there should be 5V, but I have only 3.4mv. I am going to check for continuity in the wires. Where else should I check? Is there a fuse or anything like that? Any ideas will be greatly appreciated.
Old Oct 24, 2009 | 03:55 PM
92civlude's Avatar
Default Re: TPS voltage
Which wire has this reading? Unplug the TPS, key on, engine off. The green wire should have contiuity to ground, the yellow should be 5v. Plug it back in and check the other wire. should be around .4v to .6v with the throttle closed. 4.5v to 5v WOT.
giddyup21
Mar 18, 2012 06:49 PM
f20b_guy
Nov 3, 2010 11:55 AM
stkinge
Jun 23, 2009 04:14 PM
doublejz
May 13, 2004 01:46 PM
