Honda S2000 Honda S2000
AP1 vs AP2 dyno results
Old Oct 24, 2009 | 08:23 AM
bblanco22's Avatar
New User
Default AP1 vs AP2 dyno results
My friend and i dyno tested our s2000 last night. i justed wanted to share our results. I have a bone stock 06 AP2 with 30,000 miles and he has a bone stock 03 AP1 with 35,000 miles, no mods what so ever. We had a total of three pulls each with no fans or blowers pointing at it and temp was about 40 degrees outside.
AP1 pulls:
1st- 200whp,134lbs
2nd- 200whp,134lbs
3rd-203whp,135lbs- this pull is with air box cover off and we also noticed his cat was going bad, he also is in need of a tuneup.
AP2 pulls:
1st- 208whp,143lbs
2nd-208whp,143lbs
3rd-211whp,145lbs- with air box cover off. AP2 had tune up 3 months ago not my daily driver.
We were both very happy with our results and would like to thank ***** auto and Stickerguy for all there help.
Old Oct 24, 2009 | 11:59 AM
91redteg's Avatar
Default Re: AP1 vs AP2 dyno results
cool results pretty decent power for stock
Old Oct 24, 2009 | 01:02 PM
gospeedgo1's Avatar
pretty good comparison, any dyno scans to upload? i always thought that there was a ~ 10 horsepower/10 foot pounds difference between the two.
Old Oct 24, 2009 | 01:21 PM
high_revs's Avatar
nice results
Old Oct 25, 2009 | 05:52 PM
EKris's Avatar
I read that with the intake box off, you make less power. But I guess this proves it wrong. Saw on S2ki that with the box off, creates a lot of heatsoak, and isn't good.
Old Oct 26, 2009 | 04:24 AM
rice4life's Avatar
would be nice to see the two power curve together to see power difference between the two under the peak numbers. i think that's more important than peak numbers.
Old Oct 26, 2009 | 06:31 AM
Redgts's Avatar
When I bought my s, then dude had the airbox cover off, 1st thing I did was put it back on front of him.
Old Oct 26, 2009 | 07:22 AM
turbosix.net's Avatar
there is a huge difference with the airbox cover off when you've got the hood propped up and you're sitting in a shop with a fan blowing on the engine vs with the hood closed.
Old Oct 26, 2009 | 09:40 AM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
yes, took the words right out of my mouth. for this very reason i have a spoon snorkal and a stock air box with a K&n filter.
Old Oct 26, 2009 | 10:35 AM
White Smoke's Avatar
i my honda
Global Mod
Post up the charts if you have them!
Old Oct 26, 2009 | 01:36 PM
esean93's Avatar
i have the same setup besides the "spoon" snorkel.does the snorkel really help?(not being a smartass reall want to know)
Old Oct 26, 2009 | 02:11 PM
bigmacnfries's Avatar
it won't help much on a dyno, but should help at speed..
Old Oct 26, 2009 | 02:16 PM
.john.'s Avatar
probably has something to do with the hood being open on the dyno or not. im guessing the hoods were open durig these pulls, and with 40 degree outside temps its probably cooler outside the airbox.
Old Oct 26, 2009 | 02:17 PM
esean93's Avatar
i dont think it will,the air has to go through a narrow snorkel rather than open air a little far back.i might be wrong though,no way to really know this.
Old Oct 26, 2009 | 02:21 PM
dagle's Avatar
AP2 > AP1 lets burn all the AP1's now !
and there is a way to find out, back to back dynanometer graphs.
Old Oct 26, 2009 | 05:53 PM
jdm_dc_fan's Avatar
I cant say i gained horsepower but I sleep better knowing im getting the coldest air possible. On a serious note, its a duct. Its gonna direct colder air to your box. Simple as that and it cant get anymore technical.
Oh and i gutted the air box too, if that makes a difference.
Old Oct 26, 2009 | 05:55 PM
jdm_dc_fan's Avatar
You are correct. When your on the dyno your hood is open so your oem "duct" would be enough to get the job done.
Old Oct 27, 2009 | 04:53 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
AP2 p0wNz j00!!!
Old Oct 27, 2009 | 08:02 AM
KaburaGarage's Avatar
nice finds.
Old Oct 27, 2009 | 10:01 AM
ExVtec's Avatar
Was @ a dyno day last year and an ap1 did a back to back pull with his air cover on/off and he lost power from removing it.
Only a few ponies, but it recorded on the dyno. However this could potentially be labeled heat soak as well..hard to tell?
Old Oct 27, 2009 | 12:29 PM
^^ i guess the ambient temp of the garage could affect it a bit
Old Oct 27, 2009 | 02:41 PM
cant lose power by removing the airbox lid...
Old Oct 27, 2009 | 02:44 PM
GSRkrod's Avatar
i would like to see the results with the hood shut. i have been told that the lid on makes more power and that without the lid it makes more power
Old Oct 27, 2009 | 02:48 PM
least restriction = most power... the lid off is going to make more power until the restriction loss is canceled out by the warmer (less dense) air being ingested by the engine.
one reason why i never understood when people go ITBs they dont vent their hood somehow... i would find a way to vent the hood in a way that directs cool external air right to the ITBs... instead of letting them suck up nappy *** underhood air.
Old Oct 27, 2009 | 11:25 PM
jdm_dc_fan's Avatar
these so called s2k's with ITB's and no venting or ducting are usaually the ones in the wire tuck thread. real track cars usually use some kind of duct.
