plx m300 hondata not reading below 11.9
so ive got my setup...
plxm300 with hondata. and voltage is the 0v 5afr and 5v 20afr.
but for some reason when i go to display or datalog it will not read below like a 11.9 or a 12.08 depending on what my offset is. like a -.25 to -.36 offset.
im not sure why it wont go that low.any hints? the plx is reading a 10.8 under high boost high rpm but hondata keeps just saying 12.08 dead untill i come back up past a 12.08 then it works fine.
help would be graetly appreciated
What do you have the wideband wired into? ELD? Make sure the voltage reading thow ELD is 0-5V. When I first installed my PLX it was set at like .8 minumum and 1.4 maximum. I doubt this is your problem but IDK.
Ricer no 7
Engine Management and Tuning
Dec 22, 2009 01:48 PM
