wtb: fully built b series motor
hey guys im looking to buy a fully built b series motor im looking to spend between $2k to $4k im willing to organise the frieght as i live in australia so if any one could any b series motor out there pm me
n.a b18c-1 motor, it made 216hp on hondata tuned at church automotoive, with hytech tri y header, aem 3'' cai, rc 310 injectors, bc spec3 catback, sk2 pro i.m w/68mm t.b, sk2 pro 1 cams. note* it will not come with any of these mods there sold! no dizzy, no tranny! i took the head off and got it fresh with new seals valve job ect. cause i get a verry good deal at the machine shop, 12k on block= 4 oil changes, 0 miles on head!, everything listed was brand new when installed! motor ran strong and will continue too! all it will need is a dizzy and retune ! asking $1,800 plus shipping. located in s.d c.a 92126
jdm b18c block
king race bearings
polished and balanced crank
usdm itr pistons .5 bored over- 11:4 comp. ratio with this gsr head and the suppertech valves!
new rings ect.
itr oil and water pump
arp head studs
complete oem honda head gasket set from dealership
gready timming belt
99'' gsr head (0 miles on head!!!)
all new seals and gaskets in head, manifold, injectors ect..
rocket motor sports dual valve springs and titanium retainers
Suppertech high compression flat valves, standard size! bumps comp. by .03
3 angle valve job new valve seals hot tanked ect..
will come with oem gsr cams!
oem intake manifold
stock throtle body
hondata intake manifold gasket
hondata throtle body gasket
short ram intake
stock fuel rail and injectors
ngk spark plug wires new ngk spark plugs
fresh painted black valve cover
jdm b18c block
king race bearings
new rings ect.
arp head studs
gready timming belt
oem intake manifold
stock throtle body
short ram intake
I have a 95 crank x 86.5 bore 14:1 compression longblock with clutch and flywheel. If interested pm me and I will give the details, pics, block number etc.
if your interested in taking over an amazing project that i cant afford anymore i have a fully built block and head by DH RACING its called the beast look it up if your interested web site is www.dh-racing.com and as i said i paid for the beast set up i also had a couple of extra upgrades that werent out yet so im not trying to hard to sell it on account it is an amazing motor and will be hard to get rid of it has no miles on it all parts still in original box!
got a fully built b16a longblock i want $1700+shipping and paypal fees. all you need is a transmission for about another 400-500 and intake manifold then your done!!!
