brake pedal not holding pressure
Old Oct 23, 2009 | 03:39 PM
94-integra-ls's Avatar
Default brake pedal not holding pressure
hi my 94 acura integra is having break issues it is not holding pressure i found no air in the lines after trying to bleed them and the system has no leaks what is the problem could the master cylinder be bad
Old Oct 23, 2009 | 04:12 PM
white.'s Avatar
Default Re: brake pedal not holding pressure
if there's no air bubbles then another option could be that your brake booster is bad. go to les schwab and get a free brake inspection yo.
Old Oct 23, 2009 | 04:39 PM
TunerN00b's Avatar
Did you bleed the ABS system?
Follow proper bleed order for all calipers?
If nothing else, is the master cylinder still good?
Old Oct 23, 2009 | 04:42 PM
hybrid90's Avatar
Test the booster by turning off your car.. pump the brakes till firm, hold it and turn on car.. if the pedal sinks a lil bit then your booster is fine.
Does your pedal sloowly sink to the floor when you're at a stop light or something? If so, it could be your MC.
Old Oct 23, 2009 | 05:40 PM
DAintegraGSR's Avatar
usually, well from what iv always seen is that if your booster is bad the pedal will be extreamly hard/stiff.Like a car w/o power brakes. however its the complete opposite if its your master cylinder, the pedal will be really soft and not hold pressure if your master cyl. is bad.
douple check you bleed sequence and if that doesnt fix your problem your most likly looking at a master.
Old Oct 24, 2009 | 08:55 AM
teggyboy's Avatar
It probably is your master cylinder. If you pressed down on the breaks and the pressure holds for a little bit and then slowly sinks to the ground, then it is your master cylinder.
DerekHollister
24
Sep 15, 2017 03:17 PM
Wdpfreak145
Jun 14, 2010 11:22 PM
1sikhatch
Dec 7, 2009 04:18 AM
skoolz4loserz
Mar 23, 2008 03:29 PM
eg_92vxhb
Nov 14, 2002 10:05 PM
