Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Header install today.. what tools are needed?
Old Oct 23, 2009 | 10:51 AM
EM2ABOO's Avatar
New User
Default Header install today.. what tools are needed?
ok so today i have a header and downpipe that i will be installing by my self. I haven't done this before but i know i can. What tools will i need to remove the o2 sensor, and should i have any other problems to look out for?
Old Oct 23, 2009 | 10:53 AM
GRANT!'s Avatar
Default Re: Header install today.. what tools are needed?
im confused, header and downpipe? are you refering to the b-pipe thats used on a 2-pcs. system header?
Old Oct 23, 2009 | 10:58 AM
EM2ABOO's Avatar
New User
I think. i got a short header so i believe i have the next pipe piece on the step on to full exaust. it should be the same length as the oem header meaning that the piupe connecting to the stock header is the pipe that i got included with the header
Old Oct 23, 2009 | 11:53 AM
supafil25's Avatar
well youre going to need a 12mm to get the bolts and nuts off the head on the stock header and 14mm where it connects to the rest of the exhaust and a 14mm on the bracket honding it to the block. and i think a 22mm for the o2 sensors. lol pretty straight forward. if you cant do this you prolly should be working on cars.
Old Oct 23, 2009 | 12:00 PM
It Wasn't Me's Avatar
EX manifold
LX/DX manifold
Ex Exhaust
LX/DX Exhaust
An oxygen sensor socket would help, but isn't 100% necessary. Keep in mind that you may end up needing to replace some nuts and bolts.
I wouldn't start this project unless you have someone who can drive you to the store, if need be.
Old Oct 23, 2009 | 12:01 PM
theineffable's Avatar
if you can't get the o2 sensor out, there's a special socket you can buy for o2 sensors. it has a cutout on the side of the socket
Old Oct 23, 2009 | 12:59 PM
supafil25's Avatar
another thing you can do if you cant get the o2s out is take the stock header and take it to autozone and just use their tools to take it out. so you dont have to buy tools
Old Oct 25, 2009 | 10:07 AM
boxeocampeon's Avatar
basic tools should be good
HondaHeddie
Nov 20, 2006 08:08 AM
Jeff_B
Welding / Fabrication
Apr 23, 2005 06:50 AM
CereaLand
Jun 8, 2003 02:09 PM
ITR 01-0840
Apr 25, 2002 05:01 PM
RStoR
Sep 5, 2001 06:31 AM
