how much for an LS swap???
Honda-Tech Double Platinum Member
I was talking to a friend about possible swaps and the LS issue came up. I know alot about the engine itself but i was wondering how hard it was to swao it into a CRX dx...i know that the mpfi conversion will be hard. What all would i need to do it? And the most important question....HOW MUCH IS THIS GONNA COST ME IF I DO IT? What is that average cost of a LS swap? Where is the best place to get one? Thanks alot guys.
Sean
Sean
It really varies from state to state and depending on parts you will be using...but for the most part, the mounts run around $450, shift linkage $85, Axles $200, ECU $100, Motor $700-$1000, Tranny $350-$900 (LSD), Wiring conversion $250
Check out http://www.hasport.com for more info...and I would run a search too...this Q has been asked so many times.
