zc-turbo questions
Old Aug 29, 2002 | 09:24 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default zc-turbo questions
just to be sure, will a 92-95 civic turbo kit fit my 88 crx with a dohc zc engine, and will the kit include everything i need or is it NECESSARY to run a different computer system like zydyne or hondata? i only wanna run like 5 or 6 psi
Old Aug 29, 2002 | 11:11 PM
havok hybrid's Avatar
Default Re: zc-turbo questions (Y49CRXSIZC)
yes a 92-95 turbo kit will work.. same mainifolds..... also as for 5-6 psi. u can run stock ecu for time being.. but i would just a get a zdye in the future.. im running a 92 dx block in my crx with 5 psi intercooled and on a spoon chip.. it runs fine so far
Old Aug 30, 2002 | 04:09 AM
CWBETB's Avatar
Y49CRXSIZC hit me up on honda tech IM, Im from Reading Pa not to far from you and have the exact same setup you are looking at. The new Greddy kit comes with a blue box, you wont be able to use this, you will need a vortec FPR 12:1
Old Aug 30, 2002 | 04:40 AM
.nate's Avatar
Default Re: zc-turbo questions (CWBETB)
5lbs will be fine on that motor. be sure to run a compression test first to make sure the motors numbers look good
Old Aug 30, 2002 | 05:34 AM
therealciviczc's Avatar
I'm also using the greddy kit on my ZC. Its fun. I'm currently running 8lbs on the stock ECU with just a 12:1 FMU and a Walbro 255 pump. The combo works great for the money, but the fuel pressure is rediculously high (my spelling sucks).
Since you have to buy an FMU with the greddy kit these days, I would seriously look in to either a ZDYNE, or more reasonably priced if you're on a budget, I would read up on the AFC hack. I wish I had gone the AFC route now.
Ken99287
12
Oct 13, 2011 12:32 AM
nathanie1
19
Oct 30, 2006 10:49 AM
SIReg9
Jun 22, 2003 08:20 PM
mrod006
May 2, 2003 01:43 PM
