Low Beams Not Working
Old Oct 22, 2009 | 03:29 PM
sengalang's Avatar
Default Low Beams Not Working
Alrighty guys, im pretty stumped on this one.. woke up this morning to find that my low beams arent working.. i checked both left and right lowbeam fuses and the are just fine checked the one in the Engine bay as well.. everything else light wise works ranging from high beams to tail lights.
I dont believe its wiring issues although i cant be certain since i dont have a voltmeter to check the wires..
i tried searching to see if anyone has had the same problems there was a few but their problems werent solved i guess..
Aftermarket Angel eye halo ( if that helps in anyway )
oh and its not the bulbs, they are fine as well
you guys think that the relay might have fried?
im actually not sure where exactly the relay is. Can someone point me out where it is so i can check?
2000 Integra GS-R
Thanks..
Old Dec 9, 2009 | 08:28 AM
KATKINSON's Avatar
New User
Default Re: Low Beams Not Working
I have the same problem did you find a fix?
Old Jan 15, 2010 | 02:13 PM
massicg's Avatar
New User
2000 Integra GS-R
Thanks..
Same problem with Honda Civic 2006 (Regular Bulbs) any fixes?
Old Jan 16, 2010 | 03:35 PM
rxbahamut's Avatar
Check your relay it might be stuck on high beams. That's what happened to a car a while ago on me it was just the relay. If you have a spare relay or even one from the engine compartment that will fit swap it out with the headlight relay and see what happens.
Old Jan 16, 2010 | 04:29 PM
TheAsian's Avatar
Go get a chepo radio shack Volt Ohmm meter, check and see if your getting power to your bulbs. If you are getting power to the bulbs you need to start checking for grounding issues.
No power to bulbs start checking relays replace fuses even if they look good and headlight switch
dippah
Mar 25, 2008 04:17 PM
JDM manc 10
Apr 28, 2007 06:50 PM
c_buz
Dec 9, 2004 07:10 AM
InTeGrA B18b1
Jul 14, 2004 05:50 PM
Do_Ster
12
Dec 16, 2003 06:44 PM
