Prelude Gearbox options
Old Oct 22, 2009 | 01:38 PM
computerchris's Avatar
New User
Default Prelude Gearbox options
Hi
I have a JDM Prelude (2.2 DOHC F22B engine) currently with an auto gearbox.
I am okay with the auto gearbox but let's face it, you can't beat a manual, so i'm looking at the options.
I have looked for other jdm f22b's and they all seem to be autos so looking at other models.
I can buy a prelude s 2.0 manual car pretty cheap (part body damage) and could use the gearbox and other needed parts (pedals, shifter etc).
Main question:
Is there a major drawback to using the 2.0 manual gearbox? Do I really need a JDM 2.2 gearbox for better gear range? Would a H22 or a H23 gearbox be better?
Cheers in advance
Chris
Old Oct 23, 2009 | 11:56 AM
New User
Default Re: Prelude Gearbox options
Nevermind! I think i have figured this out now after a lot searching.
A lot of people seem to run away at the talk of an F22B engine
Here's what I figured after finding the gear ratios for the two gearboxes in question.
F22B Manual (M2J5) - Ratios 3.307 - 1.810 - 1.269 - 0.966 - 0.787 - 4.062
F22A1 Man (M2L5) - Ratios 3.307 - 1.810 - 1.230 - 0.903 - 0.705 - 4.062
Barely anything in it. After putting the figures through a gear calculator it reckons the F22A1 gearbox would accelerate about the same and top end speed would be slightly better.
So If that is correct then buying the 2.0 Prelude and using it as my donor may be a good idea after all.
Chris.
Old Oct 23, 2009 | 12:17 PM
A Blue Lude's Avatar
Both those transmissions are considered pretty crappy. The H-series (and some Fs) have 4.266 final drive transmissions and are much more desirable.
Old Oct 23, 2009 | 01:24 PM
NirVTEC's Avatar
Basically anything that doesn't have the 4.0x final drive.
For comparison, my friends H22 w/ F trans with 4.0x FD would drop out of VTEC for ~10mph on the 1-2 shift. WEAK!
Old Oct 25, 2009 | 07:59 PM
Kronn 98SH's Avatar
https://honda-tech.com/forums/honda-prelude-4/prelude-h-series-transmission-codes-ratios-master-list-2548441/
That might help you some.
MauricioJDM
Jun 29, 2010 04:15 PM
broken ninja
Nov 20, 2008 10:14 AM
Prelude_1992
Aug 9, 2008 10:31 AM
uber_Rabbit
Apr 7, 2004 06:21 AM
