ls/vtec b16a2 head
Old Oct 22, 2009 | 08:46 AM
jdragon1974's Avatar
Default ls/vtec b16a2 head
ok so here is my problem, i have an ls/vtec with b18a1 bottom and b16a2 head, I rebuilt it like 8000 miles ago, used a non metal head gasket, and soon as i notice it leaked i replaced it with a metal one, also while having the head off i replaced the springs and retainers with itr ones. engine ran fine before that. now I put the head back on, got new arp head bolts and torq to 80 pounds for final torq, i have s300 so i can adjust just about anything, so when it runs it acts like there is no power , when i rev it, it boggs till about 3000 then its fine, when i release the gas it drops below 1000 to about 300 then comes back to 950, no smoke or bad idle, timming is perfect, injectors are good, replace all gaskets on the head including the valve stem seals. no check engine lights or anything. try to drive it and it just bogs then back fires and dies.
when I took the head off there was a little bit of oil on piston 1 after doing the head gasket there is no oil there. just scratching my head on this one. Please help..also i have gsr cams. thanks for reading.
Old Oct 22, 2009 | 10:25 AM
ek-g6's Avatar
Default Re: ls/vtec b16a2 head
It may needs a good tune, on a dyno and such.
Old Oct 22, 2009 | 10:35 AM
yeah its got a tune on it.. s300 tuned well had my old tune but I have not changed anything performance wise, the map should still be good. the only thing i canged was head gasket and the itr valve springs and retainers..
Old Oct 23, 2009 | 10:33 AM
problem solved ended up being 2 injector wires that were bad..lol how simple is that..lol thanks for the help h-t
Old Oct 24, 2009 | 06:55 AM
SQ is the SQUAD's Avatar
i ran into the same problem. my car sat for a month cuz i though i blew the motor, lol. good luck!
boostedb16a
20
Aug 27, 2013 06:55 PM
christian7750
30
Apr 4, 2009 04:39 AM
exownzu
Sep 22, 2006 09:56 AM
AllMotor12s
Apr 17, 2005 05:56 AM
CRXGSR
Mar 11, 2003 09:28 PM
