K20Z3 swap in RSX 2002 need help!
Hey guys,
My friend blew his motor in his 2002 RSX
We found a K20Z3 motor from a 2007 Civic Si
What do we need to do the swap in the RSX with the RSX tranny?
Motor looks abit different so we want to know what changes need to be made to do the swap before purchasing the motor.
Let me know guys!
Thanks in advance!
Let me know guys!
Thanks in advance!
swapping a z3 has a lot of issues the "B" people have trouble getting their heads around.....drive by wire for starters( no throttel cable), different speed sensor on the trans, shift arms are backwards and need to be swapped with dc5 parts( drilling and tapping required).....I think the crank sensor is different as well but do not quote me on that.....If the car is a type-s, swap all the sensors, use the type-s tb and loose the z3 trans would be the easiest.....If it a base, well you are going to need kpro, a type-s motor harness, a type-s tb and I/M and just follow the type-s advice.
bambam
13
Aug 23, 2019 08:03 AM
JC-aka-Wallabe
18
Jul 21, 2002 11:47 AM
