putting injector resistor box on p30?
Old Oct 21, 2009 | 07:43 PM
cehcivic15's Avatar
Default putting injector resistor box on p30?
can it be done? do i just wire the 4 wires to my 4 injector ground wires or will my ecu not work with the box? if this does work, will my stock b series injectors work?
i pretty much understand the benifits from the resistor box just dont know if it will work with my ecu and injectors
Old Oct 21, 2009 | 08:14 PM
mtber's Avatar
Default Re: putting injector resistor box on p30?
You only need a resistor box if you are running low impedance injectors.
The ecu has nothing to do with your resistor box.
The ecu sends ground pulses via signal wires to each injector.
The resistor box gets wired into the power wire that runs to each injector....
food
Dec 29, 2007 06:49 PM
ironcheftony
Apr 14, 2005 02:39 PM
BoostBoi
Nov 13, 2004 11:50 PM
Honda_Tengoku
Apr 11, 2004 03:00 PM
dustin
Jun 17, 2002 02:09 PM
