MSD DITRIBUTOR need fire
Ok i think its not simple to explain so i will make my possible i want fire....
i have broken my oem distributor and i have buy the msd Kit
*6AL
*MSD DITRIBUTOR
*MSD SPARK WIRING
*COIL BLASTER
*IGNITER DRIVER
my car is a 99 type r and a got a obd1 conversion so its not a harness conversion its a costum conversion to the ecu
i have plug my 6al direclty to the battery (red black)
and i got also 4 wire from the 6al and they go to the external coil 2negatif and 2positif all wirring is correctly conected like on the diagram
my question is what i need to look if i got no fire in my case (FUSE???)
AND IF some one have the diagram of the OEM DISTRIBUTOR WIRING i will chek if i got power on the distributor and after i will chek if i got power on the coil (do you think i can by pass the 6al AND ONLY PLUG THE COIL DIRECTLY ON THE BATTERY thank you
*6AL
*MSD DITRIBUTOR
*MSD SPARK WIRING
*COIL BLASTER
*IGNITER DRIVER
and its my distributor i got two connector on it one for the OEM plug and the other i connect the MSD driver (bottom of the ignitor) so i dont know witch wiring do what!!
terribl3jon
Welding / Fabrication
Mar 4, 2006 06:44 AM
