Suspension & Brakes Theory, alignment, spring rates....
suspension for street/strip
Old Oct 21, 2009 | 06:44 PM
slvrlude's Avatar
Default suspension for street/strip
Whats going on....i need a new suspension set up and i need some opinions, knowledge and advice on what to choose. i want to get the most out of my setup, so im looking for the best option to get me the most out of my tires (as far as grip when acceleration and shifting). i have a a 93 eg with a boosted b16 (lsd) with 340whp. im running 205/50/15 falken azenzis on the street and looking to get slicks for the strip; i have replaced all oem bushings with polyuerathane bushings in the front and rear; no traction bar/sway bars, but i do have the rear 3 piece em racing strut bar, along with a skunk 2 lower tie bar. thats probably all you guys need to know for this. what i'm looking for is a full coilover with dampning adjustability, so i could modify the setup when needed, just so the street driving would be tolerable. I don't dd the car, so its not too big of an issue, but i know we all try to get the best of both worlds. any help would be appreciated. thanks
Old Oct 26, 2009 | 09:57 AM
slvrlude's Avatar
Default Re: suspension for street/strip
bump
Old Oct 26, 2009 | 12:39 PM
skunk2.com's Avatar
Skunk2 Pr C's offer the adjustability you are looking for.
Pro C's are a Mono-Tube design that feature 12 position rebound/ compression adjustment, that actually show a change at each position, allow separate ride height adjustment from spring position/ pre-load. We also sell additional spring rates if you would like to customize them. They come with 10K (front) and 8K (rear).
Old Oct 26, 2009 | 02:38 PM
phunhaus's Avatar
Read up on polyurethane bushings here. Most people recommend against them unless you're going to service/replace them annually.
Old Oct 30, 2009 | 06:21 PM
slvrlude's Avatar
will do....thanks
skunk2--thanks for the info...i've been looking at those for a while and reading reviews on them...we'll see
slvrlude
Oct 26, 2009 09:56 AM
Grr Wolfe
47
Jul 13, 2006 01:50 AM
ian04rsx
Jul 13, 2005 01:56 PM
WH0R3nEF9
Apr 23, 2005 12:19 PM
FF DRFT
28
Aug 20, 2004 11:08 PM
