fuel, spark, NO START WTF!!
Old Oct 21, 2009 | 05:45 PM
miller9779's Avatar
Default fuel, spark, NO START WTF!!
Everything is hooked up. Got spark. Got Fuel Pressure. BUT I heard a weird noise that sounds almost like the starter isn't dis-engaging, however the starter moves freely when inspected. I say its a grinding noise but my buddies the mechanics says its not really a grinding.... just a weird strong noise/grinding when the motor turns over. I know the motor is chill and good, but its got a new tranny. Let me know if anyone has any ideas. As of right now its a mystery that needs to be dealt with ASAP. Thanks - mil
Old Oct 21, 2009 | 05:53 PM
joelmatt89's Avatar
Default Re: fuel, spark, NO START WTF!!
But I would say you are correct in focusing in what is causing the sound. You know there is a problem there so focus on that first. If you take the starter out do the teeth look eaten up at all.
Just because you have fuel pressure doesn't mean that fuel is getting into the engine. Could be bad injectors or the wiring could be bad. I wouldn't rule that out quite yet. If you turn the engine over a little while and then remove the spark plugs are they moist and smell like fuel.
Next thing to check: Are the plug wires hooked up in the correct order. How do you know the motor is "chill and good". Did you see it running previously with your own eyes.
Old Oct 21, 2009 | 08:13 PM
Former User's Avatar
Sounds like a bad starter.
Can you push start the engine?
00Civik
13
Aug 22, 2011 06:37 PM
neoc03
Jan 2, 2010 10:26 PM
miller9779
Oct 20, 2009 10:11 PM
michaeljenkins
Apr 26, 2008 11:51 PM
Jabinya
Jul 13, 2007 05:49 AM
