No fuel out of injectors
Old Oct 21, 2009 | 03:44 PM
Gkdc182's Avatar
Default No fuel out of injectors
I have precision 1000cc injectors in my b series...i have about 1000 miles on them and now there are no fuel coming out of the injectors at all...we get pressure...i run hondata S300....checked all fuses and we get power to the injectors and they do click...Help please!?
Old Oct 21, 2009 | 08:39 PM
night's Avatar
Default Re: No fuel out of injectors
ground?
Old Oct 22, 2009 | 05:38 AM
fcm's Avatar
fcm
Old Fart
If the injectors have power then it is an ECU/ECM problem as it is a ground pulse from the ECU/ECM that "fires", [triggers] the injector. 94
Old Oct 22, 2009 | 06:57 AM
QUICK8CIVIC's Avatar
does the ecu throw a CEL?
Old Oct 22, 2009 | 08:00 AM
night's Avatar
i meant the ecu ground, the one on the manifold or thermostat housing.
Old Oct 22, 2009 | 11:25 AM
Gkdc182's Avatar
all grounds have been cleaned....what goes bad in the ecu is it fix able?
Old Oct 22, 2009 | 11:47 AM
night's Avatar
honda ecu's dont die. unless the wrong injectors were on it at some point.
Old Oct 22, 2009 | 12:27 PM
HRTuning's Avatar
Parts can malfunction at any time.
OP>Start datalogging and watch during cranking. Your RPM should change from 0 during the cranking process. If it is, then you have two other things to look into immediately.
Whether the fuel pump is priming and getting power...
Whether the injector drivers in the ECU are bad.
Old Oct 22, 2009 | 01:06 PM
Gkdc182's Avatar
ok i will try that
Old Oct 22, 2009 | 01:57 PM
HRTuning's Avatar
If there's no change in RPM, your distributor may be at fault and the ECU may not be getting a correct signal from the CYP sensor. Please keep posts here instead of PM so others learn from this as well.
rlembitz
Dec 24, 2010 09:04 AM
jansenrw
Nov 19, 2005 08:44 PM
evilone
Oct 8, 2004 08:30 AM
