no start
Old Oct 21, 2009 | 01:55 PM
miller9779's Avatar
Default no start
smells like gas. small pop out of exhaust like the timing might be off. no start. good fuel pressure. good spark.
Old Oct 22, 2009 | 09:43 PM
PilotOnDubs's Avatar
Default Re: no start
any dtc's? (diagnostic trouble codes) (check engine light)
have you checked engine timing?
make sure your camshaft and crankshaft are aligned tdc (top dead center)
theres also a tdc/crank/cyl sensor inside the distributor...
Old Oct 25, 2009 | 11:52 AM
usohc's Avatar
More details. Is it turnin over? Can u hear the fuel pump going on? Cycle the fuel pump a few times. Check for spark at the wires. Also check if the engine was flooded with gas.
Felipe_Rdz
May 8, 2013 02:27 PM
brandy
56
Aug 12, 2009 05:44 AM
HondaRexBoi
May 13, 2008 12:08 PM
dc2doi
Jan 6, 2008 01:43 PM
Tony Ignatz
17
Oct 14, 2004 01:20 PM
