replacing headgasket, is there any else i should replace too?
Old Oct 21, 2009 | 11:36 AM
jeremyrocksursox's Avatar
Default replacing headgasket, is there any else i should replace too?
alright so my headgasket went bad and im going to replace it
i plan on changing the valve cover gasket too, is there any else i should replace besides that?
Old Oct 21, 2009 | 12:57 PM
Frost7177's Avatar
Default Re: replacing headgasket, is there any else i should replace too?
i would replace the water pump ,timing belt, t-belt tensioner and thermostat.
Old Oct 21, 2009 | 01:09 PM
coreysef's Avatar
x2 really just timing belt and water pump,the others if no problem with them you dont have to but I would since the heads going to be off anyways.
Old Oct 21, 2009 | 01:11 PM
civic_r87111's Avatar
Buy head studs too, ur suppose to replace the head bolts anyway any time the head is taken off but most ppl don't do it.
gratua
Feb 17, 2012 06:12 PM
armintheman
Oct 4, 2010 01:05 AM
saemoonyang
17
May 5, 2010 05:56 PM
1slow02
Sep 30, 2009 10:05 PM
. M i c h a e l
Oct 19, 2005 05:39 PM
