Upgrading larger Throttle Body...
Old Oct 21, 2009 | 12:30 AM
slide inside's Avatar
Default Upgrading larger Throttle Body...
if i have an aftermarket skunk2 manifold on a b16a head with a stock TB (i think) What would i have to do to fit say a 74mm Throttle body? Or anything 68-74mm? Im a noob so just need to know before i pick one up.
Old Oct 21, 2009 | 01:15 AM
thumper64's Avatar
Default Re: Upgrading larger Throttle Body...
Go read up on the effects it will have. Both the intake and throttle body. You'll have to basically port match the intake manifold to the same diameter as the TB. You'll need an air powered rotary tool and burrs to remove the aluminum.
shahriar35
Jan 31, 2010 12:13 AM
blazin415
10
Dec 30, 2007 01:20 PM
allnaturalb16
Sep 26, 2006 02:09 PM
