fittings in the valve cover?
Old Oct 20, 2009 | 08:33 PM
hanji's Avatar
Default fittings in the valve cover?
does anyone knows where i can get some AN fittings welded on my valve cove on this site"? i used the back of the block to run the breather can but it kept on puking and unfortunately i spun a baring due to kinked return line. if i remember correctly, someone was welding them on honda-tech a while back. i just cannot find the link. any help is appreciated.
Old Oct 21, 2009 | 08:47 AM
rota92
Guest
Posts: n/a
Default Re: fittings in the valve cover?
Any one of the big names on here can do it for you, but any welding shop can take of it too. It's just banging a hole, cutting a small baffle, and welding the bung.
Old Oct 21, 2009 | 09:47 AM
champLSinteg's Avatar
pmed
Old Oct 21, 2009 | 02:05 PM
Arisaka's Avatar
New User
Do you have a pic of the inside with the small baffle installed?
I will weld it myself but wanna see how it's positioned.
Thank you.
Old Oct 21, 2009 | 03:14 PM
fav6052's Avatar
Alot of local welders near me we're iffy about welding them for me since VC are cast aluminum. I finally found a guy to do it for me fairly cheap and they came out perfect. Let me dig through my pictures on iphoto and see if I have pics of the baffling.
Arisaka's Avatar
New User
That will be appreciated.
Old Oct 21, 2009 | 03:40 PM
kommon_sense's Avatar
www.kingmotorsports.com offers this service.
Old Oct 21, 2009 | 07:43 PM
rota92
Guest
Posts: n/a
The baffle is usually just a small tab of aluminum on an angle, I don't want to post pics and mess other people up.
FWIW it's not all that neccesary to be pulling from the VC. Just vent the block properly and you'll be good to go. ::Flamesuit on::
Old Oct 24, 2009 | 06:46 PM
hanji's Avatar
vc is the proper way to do it, back of the block always fill up the the can and i had a bad experience.
TravisBiggie
Jun 23, 2012 07:40 PM
ImportMotorSpec
Mar 10, 2006 05:17 AM
ImportMotorSpec
Mar 9, 2006 08:52 PM
budget
Feb 16, 2005 10:37 AM
turboteg2nv
Nov 28, 2004 08:24 AM
