96 hx auto to manuel converted. Squishy brakes
I did not do the conversion i recently bought the car. The brakes dont work intill the pedal is basicaly to the floor. I have no grinding nothing. Master cyclinder is leaking or anything like that. Im gunna try to re bleed them. And see if i get any pressure back. Any suggestions?
Is the fluid in the master cylinder reservoir low?
Also check for leaks from the front calipers and rear wheel cylinders. Air must have entered the system somewhere.
dmeconitas
May 30, 2012 01:40 AM
goldegg
Aug 11, 2007 09:00 PM
