whats wrong with my tegg
Old Oct 20, 2009 | 07:55 PM
lilvietboy's Avatar
Default whats wrong with my tegg
so i took it to the shop and he said its a leaking headgasket. and said i had a bad rocker arm?
took off my VC and my rocker arms seem fine. im pretty positive i need a valve adjustment its making this noise
http://www.youtube.com/watch?v=mvCdVjFLKik
thinking the noise could be dealing with the oil? since their was a headgasket leak water got inside (if you guys are in ca it was the day it was raining... A LOT)
Old Oct 21, 2009 | 11:15 AM
ek-g6's Avatar
Default Re: whats wrong with my tegg
Sounds like it needs a valve adjustment. To be sure your do a leakdown test to confirm leaking headgasket or rule it out.
Old Oct 21, 2009 | 12:41 PM
Ice-Nine's Avatar
My car makes that sound but not nearly as often. Haven't fixed it yet but I am pretty sure my problem is as ek-g6 says, valve adjustment.
Old Oct 21, 2009 | 03:06 PM
lilvietboy's Avatar
what is a leak down test?
Old Oct 21, 2009 | 03:12 PM
STRDAGEY88's Avatar
Leak down testhttp://www.team-integra.net/forum/di...g+Common+Topic
Old Oct 21, 2009 | 08:23 PM
lilvietboy's Avatar
running some tests tomorrow so hopefully youre right and i just need a valve adjustment and to replace my HG.. would really like to keep this to a minimum money spent
Old Oct 21, 2009 | 08:43 PM
rayzah_blade's Avatar
funny how the true teggy enthusiasts on this site always lead the less knowledgeable to the articles on team-integra.net.... at lest some of us know where the real info is lol.. good luck on the testing, hopefully all you need is a little valve lash
Old Oct 21, 2009 | 09:00 PM
lilvietboy's Avatar
oh how i hope its that.. im praying its not a rod knock smashing my cylinder wall... if it is my two options: someone hook it up with a b18a1 or b18b1 for under 500 (if i manage to get 500) maybe even trade my SSR's for a motor, option two: sell wheels, part out my teg (would like to keep her) and than just ride my bike places >.> (not motorcycle) until i get enough money for something new.
Old Oct 21, 2009 | 09:23 PM
sixfourkiller's Avatar
well i have a b18b1 head that i can sell to u that i took taken off my teg to put a build head.. and once someone said something ever one else go with it... but its not a valve adjusted u need cuz from what i heard its not a ticking noise that what u would hear if u need one.. or like a fast tap tap npise. and i know hear that noise from that video.. so that not it but good luck and if u need a head PM me
Old Oct 21, 2009 | 09:39 PM
lilvietboy's Avatar
ill let you know but as of now i have a b18a1 and my friends got a b18a1 head if its something in the head. im just worried its a rod knock cause than im F***ed was hoping my teggie would make it to 300K+ =[
Old Oct 22, 2009 | 03:01 PM
lilvietboy's Avatar
is there any way i could do a test to check if its a rod knock??
Old Oct 22, 2009 | 03:05 PM
vzqz18's Avatar
same here man it only makes that noise when i shift to 2nd and 3rd but once i hit 4th no sound
Old Oct 22, 2009 | 08:42 PM
lilvietboy's Avatar
mine does it when its idle rod knock? ****ed up the cylinder walls? found some nice tegs on CL
Old Oct 22, 2009 | 10:19 PM
DC206R's Avatar
teamintegra FTW.
friutoftheLude
Apr 27, 2013 02:13 PM
kornkid21792
Mar 3, 2010 01:06 PM
s2k10psi
Honda S2000
Nov 25, 2006 07:31 PM
OBRJosh
Aug 9, 2006 05:25 PM
SpoolnByYou
Feb 8, 2006 03:59 PM
