GAUGES TURN OFF AND ON BUT CAR DOESNT DIE WHEN DRIVING
Old Oct 20, 2009 | 06:57 PM
asbloodrunsblak's Avatar
Default GAUGES TURN OFF AND ON BUT CAR DOESNT DIE WHEN DRIVING
Going down the road tonight my radio, speedometer, tach, and water temp gauge all hit bottom as if the car were off. They stayed off long enough to here the beeping as if you parked and took the key out. But the car didnt die it didnt act funny or anything. the gauge panel back light stayed on though. I could only guess a loose ground or something. Has this happened to any1 else? what was the problem?
Old Oct 20, 2009 | 07:02 PM
slow96lude's Avatar
Default Re: GAUGES TURN OFF AND ON BUT CAR DOESNT DIE WHEN DRIVING
what year car. There are some different symptoms for different years
Old Oct 20, 2009 | 07:13 PM
H22_EK's Avatar
Is your battery good? Might be your alternator not charging the battery.
Old Oct 20, 2009 | 07:19 PM
slow96lude's Avatar
his car wouldnt stay running....wow. Its more than likely the backup fuse or a ground. If its a 96 is probably the clip behind the motor. rubbing and grounding out
Old Oct 21, 2009 | 04:06 AM
Inliner's Avatar
this happened to me in my coupe it ended up being my alternator plug. the clip was broken and wouldnt stay on when it lossened up enough my dash would die but the car would still run but wasnt charging which i found out the hard way.
Old Oct 21, 2009 | 08:58 AM
its a 92'. I checked the battery when the car is off is 12v and checked it when its on its still about 12v-12.2 actually. I dont know ima have to check it out during the daytime after work. I dont know what the deal is yet but thanks for the suggestions
JDM.Accord
Jun 18, 2015 03:47 AM
d15vtecivic
Jun 11, 2007 09:42 AM
PreludePhill
Sep 3, 2006 03:25 PM
m1rocs
Apr 8, 2006 01:44 PM
shadowdawn
Aug 9, 2003 06:23 PM
