GSR high speed shake and noise (HELP!)
Old Oct 20, 2009 | 04:13 PM
dapek's Avatar
Default GSR high speed shake and noise (HELP!)
Ok, so i have searched as well as asked this question on another forum but never got a definitive answer.
I have a 96 GSR and a couple months after i purchased it, I started hearing noise during acceleration on the drivers side. As the next couple weeks passed it got a little louder. I'm also having some shaking of the car at speeds around 65mph and up.
My guess would be the drivers side axle could be my problem, at least with the noise issue. As far as the shaking, could it be that i need an alignment?
Thanks, any input would be awesome.
Old Oct 20, 2009 | 05:13 PM
94civiccupew/b7's Avatar
Default Re: GSR high speed shake and noise (HELP!)
sounds like the axle. i'd just buy a pair of axles and change both
Old Oct 20, 2009 | 06:29 PM
dapek's Avatar
Thanks, i'm sure the noise is from the axle but i'm not too positive of that being the reason for the higher speed vibrations/shaking.
Old Oct 20, 2009 | 08:00 PM
steveo135's Avatar
axles are your problem... as you've stated, you know that they do make noise but also when the inner CV joint goes (tranny side of axle) it can cause vibration in the car
If I were you I would stay away from autozone axles and would look into raxles.. they have a lifetime warranty and are built very well
Old Oct 20, 2009 | 08:08 PM
artin01's Avatar
axles buddy thats all chenge it and you are good. done
Old Oct 20, 2009 | 08:22 PM
dapek's Avatar
Perfect man thanks for the info, i've already found out sadly how garbage autozone axles are
Old Nov 13, 2009 | 07:23 PM
dapek's Avatar
Changed both axles a couple weeks ago and the noise is still there. Could it be my intermediate shaft like the part on the drivers side of the tranny that actually goes into the tranny?
Old Nov 13, 2009 | 08:02 PM
HKSkiD714's Avatar
Icon6 Re: GSR high speed shake and noise (HELP!)
I have a problem like that too.
Like when I go on the freeway the streering wheel shakes?idk
And like when I stop my rpm stays at like 1.5 rpm and it go's up and down like up to 2,000...
There is a screw on the intake manflod and I screw it in a little and it stops from going up and down.wired.any help???
Old Nov 13, 2009 | 08:05 PM
HKSkiD714's Avatar
I have an eg6 with ab16a swap by the way lol
Old Nov 13, 2009 | 09:03 PM
dntnedvtec's Avatar
Sounds like a wheel balancing/aligment is due. Your idle issue is due to a vacuum leak. Check all your hoses from your intake manifold and so on. The little screw in your throttle body is known as an idle screw. It allows a small amount of air to your engine, thus controlling your idle. I don't know why it is there, but its there for a reason.
Old Nov 13, 2009 | 09:06 PM
dntnedvtec's Avatar
You never specified what kind of noise. High pitch sreeching, low grinding, fast ticking, slow ticking, etc...describe you sound.
Old Nov 13, 2009 | 09:33 PM
dapek's Avatar
It's a low dooh dooh dooh noise coming from the bay in front of the steering wheel. It makes noise under acceleration, during cruising, and in neutral slowing down but if I'm turning right then the noise is almost non existant.
Old Nov 14, 2009 | 01:11 AM
Slain's Avatar
wheel bearing maybe ?
Old Nov 30, 2009 | 07:59 PM
ejb16acoupe's Avatar
New User
could be many things .. like axles ..alignment.. berrings hope you find it soon
Old Nov 30, 2009 | 08:46 PM
Moi Zver' (GSR)'s Avatar
sounds like a wheel bearing, does it pull right or left when u drive??
alignment is a must if it starts shaking at 65mph means bad alignment
Old Nov 30, 2009 | 09:10 PM
dapek's Avatar
Three week old thread, was the wheel bearing.
/thread
dlewis2583
Jan 25, 2011 05:41 AM
xiztence
Jul 13, 2007 04:25 AM
astig* DC2
Sep 20, 2005 12:23 PM
blkgsr03
Jan 17, 2005 09:11 PM
flip1199
Oct 24, 2002 10:58 AM
