Obd1 FANC-A12 wiring.
Old Oct 20, 2009 | 03:43 PM
likwidchz's Avatar
Default Obd1 FANC-A12 wiring.
Does the A12 pin from the ecu go directly to the same circuit that the thermostat is wired to?
when the ecu signals pin A12 active that pin goes negative switched out..there is continuity between pin A12 and ground and when pin A12 is not active the circuit is open.
If i find whichever wire on the thermostat when grounded turns on the fan, this wire should go to Pin A12 <-- this is what im trying to figure out.
--Aaron
myefhasaname
Feb 27, 2013 08:45 PM
tallkan
Mar 1, 2009 12:00 PM
tiresmoke
Apr 19, 2004 05:12 AM
Pimpstecy
Jun 23, 2003 09:57 AM
Pimpstecy
Jun 4, 2003 04:43 PM
