How do you take out the back seats?
fold the seat down, on each end, at the bottom there is a hinge on each side. unbolt the hinges from the seat. now you will be able to see one bracket holding the bottom of the seat to the car. take out that bolt, then that side of the seat pulls up and towards the front seats. there are two metal things that you just have to move the seat around till they pull out.
make sure you dont screw the middle bolt too tight..because i snapped mine when
i try to put it back on. Lucky for me the broken piece came out easy or i'll have to drill it out. good luck bro
