Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 Civic Driver Window issue
Old Oct 20, 2009 | 12:27 PM
Blaze87's Avatar
New User
Default 03 Civic Driver Window issue
Hello,
Yesterday my driver window was working fine, no sluggishness, no weird noises. It was raining or anything either. Then today when i get into my car the window wont work. When i press the button all i get is a click. I checked all the fuses except for the number 23 internal because i did not have time to unhinge the box, but i dont think its the fuses. I also tried moving the rubber boot around but that did not work either. Any ideas?
Old Oct 20, 2009 | 02:27 PM
eviee1973's Avatar
Default Re: 03 Civic Driver Window issue
Check to see if regulator works when 12 volts are applied, if it works then check to see if power is getting to the harness that plugs in to the regulator, if not start working backwards with a schematic. There is a relay in the fuse panel, while the power window control unit is inside the drivers door switch. Would be more best to try switching the control unit with another known working one.
Old Oct 21, 2009 | 05:45 PM
2kcoupedude's Avatar
eviee has a good point. I would swap a good known drivers door switch to see if the driver window works. If that don't work check the regulator, I've replaced tons of those
92-CivicLX
Sep 23, 2013 07:46 AM
Basilias
Dec 29, 2010 06:57 AM
s4325
Aug 4, 2010 09:31 PM
99hondacura
Feb 6, 2007 06:54 PM
