Will GSR OBD2 cat work on OBD1? Need answer ASAP
Old Aug 29, 2002 | 06:04 PM
92SiB18C1's Avatar
Default Will GSR OBD2 cat work on OBD1? Need answer ASAP
ElectronicBlueGSR is selling me a OBD2 cat for my OBD1 car because I need one to pass inspection and emission. Will it work on my car? Will CEL come on? I need answer ASAP Thanks
Old Aug 30, 2002 | 04:12 AM
92SiB18C1's Avatar
Default Re: Will GSR OBD2 cat work on OBD1? Need answer ASAP (92SiB18C1)
ttt
Old Aug 30, 2002 | 10:41 AM
92SiB18C1's Avatar
Come on, really need help here
Old Aug 30, 2002 | 10:58 AM
JD_B18CDX's Avatar
Not much difference between Testpipe and stock GSR OBDI cat. 1-3 hp on the dyno accross the powerband.
But if ur really interested, Focuz has a nice build. Order it at your nearest performance store.
Testpipe.com sucks.... dont waste your time and money on this company.
https://honda-tech.com/zerothread?id=252491
Hope this helps out.
Old Aug 30, 2002 | 11:48 AM
jmm96gsr's Avatar
Default Re: Will GSR OBD2 cat work on OBD1? Need answer ASAP (johnd)
the only difference should be that the obd2 cat will have two O2 sensor holes. i might be wrong but obd1 b18c1's have the O2 sensor attached at the end of the exhaust manifold which makes the exhaust manifold slightly longer. hope this helps
Old Aug 31, 2002 | 07:05 PM
R_yd's Avatar
Default Re: Will GSR OBD2 cat work on OBD1? Need answer ASAP (jmm96gsr)
obd1 gsr's have the o2 sensor in the cat, not in the header. if you get an obd2 cat (gsr), it'll have 2 holes in the cat... plug the secondary bung.
Old Sep 1, 2002 | 03:00 AM
GZR4DR's Avatar
Default Re: Will GSR OBD2 cat work on OBD1? Need answer ASAP (Rspool)
Also i believe OBD II cats are a little longer. It might not bolt up.
Old Sep 1, 2002 | 09:31 AM
Nameless RB26's Avatar
testpipe.com sucks?
I just ordered my tp from them, is something going to go wrong? I haven't got it yet...
potmilkz
Jan 11, 2008 07:45 PM
Phatch99
Jul 24, 2004 03:42 PM
B00ST2nR
Feb 27, 2004 08:17 AM
B00ST2nR
Mar 20, 2003 01:14 PM
paulyman
Aug 26, 2002 04:40 PM
