Skunk2 pro 1 cams breaking valvetrains??
Old Oct 19, 2009 | 06:28 PM
99kleansi's Avatar
Default Skunk2 pro 1 cams breaking valvetrains??
Has anyone else heard that there are issues with pro 1 version 2 cams breaking valves? What's the issue if they are and what's the solution from their manufacturer?
Old Oct 19, 2009 | 07:12 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Skunk2 pro 1 cams breaking valvetrains??
If they are breaking valves, chances are you have high compression pistons, didn't check all your clearances (claying your motor) and the valve smacked the piston. Or you were just unlucky and they just hit anyway.
Does that answer your questions?
Old Oct 19, 2009 | 07:35 PM
99kleansi's Avatar
No I understand that. I was told skunk2 was contacted regarding this. It was not a simple piston to valve clearance issue. I am skeptical to the story as well and suspect the cams were not degreed properly
Old Oct 19, 2009 | 08:15 PM
if a valve spring is too stiff, it can snap the head of the valve off, also making it drop into the chamber.. what valvetrain are you using?
Old Oct 19, 2009 | 08:25 PM
99kleansi's Avatar
It's not my head. The valvetrain was super tech didn't see the sprig pressures.
Old Oct 19, 2009 | 08:26 PM
99kleansi's Avatar
I would just Like to confirm or deny the rumor. If it's not the cams I will go ahead with my build and ensure they are degreed right when it comes to my motor.
Old Oct 20, 2009 | 08:11 AM
Viorent GRIP!'s Avatar
It's Skunk2 all their crap breaks.
Old Oct 20, 2009 | 03:05 PM
99kleansi's Avatar
Really? Like what? I have never had any issues with anything I own. That's why I was questioning these cams.
Old Oct 20, 2009 | 03:17 PM
fmfkid250's Avatar
We are not talking about crower here.
I never seen anything of skunks break.
Old Oct 20, 2009 | 03:43 PM
B18c1turboedEK's Avatar
If i recall correctly, Tony1 broke his skunk 2 cams in half.But i still run them hahahah
Old Oct 20, 2009 | 06:06 PM
fmfkid250's Avatar
He goes 8's!!!! what wouldent break?
Old Dec 8, 2009 | 08:34 AM
fly_high_gsr's Avatar
well it has to do with cam timing not product i got pro1's with pro springs almost 2 years rev up 2 9k all day np either u over rev u'r motor or cams 2 advanced.
Old Dec 8, 2009 | 11:25 AM
jdm inc's Avatar
Did u degree the cams in?
Old Dec 8, 2009 | 11:33 AM
SPOOLINmatt's Avatar
to heavy of a spring bottoming out? Coil Bind?
Old Dec 19, 2009 | 08:10 AM
99kleansi's Avatar
Just wanted to bring this back once more. Got the Pro 1s after all degreed them in had some problems on the dyno. So we set them straight up and they worked a little better. Also anyone running these with pretty loud valvetrain?
Muckman
Apr 7, 2012 06:56 AM
RoB316
22
Oct 28, 2007 12:31 PM
ohsnapzafingcu
May 31, 2007 06:58 PM
PowerHouse
Mar 28, 2004 07:57 PM
