Toda vs. CTR vs. IB Spec Pistons
Old Aug 29, 2002 | 05:05 PM
GQ 05YellowEVO8's Avatar
Default Toda vs. CTR vs. IB Spec Pistons
I was wondering about these pistons. They are all different prices, but by the way they're designed do you offer the same amount of compression increase?
Say we look at 81.5mm pistons for all three? Would they all offer the same compression increase for a 1.8L block?
Old Aug 29, 2002 | 05:23 PM
ImportReview
Guest
Posts: n/a
Default Re: Toda vs. CTR vs. IB Spec Pistons (VTEC-MAN95GSR)
Well, I offer, for a GSR motor compression say..
11.8 and 12.8
The valve reliefs are deeper than CTR pistons, and of course, they are forged.
Thanks.
Jeff
Old Aug 29, 2002 | 05:36 PM
Dropspeed's Avatar
Default Re: Toda vs. CTR vs. IB Spec Pistons (ImportReview)
I'm not a JDM junkie, Does Toda make pistons??????
Old Aug 29, 2002 | 05:42 PM
Eric R's Avatar
Default Re: Toda vs. CTR vs. IB Spec Pistons (Dropspeed)
Oh yeah they do!
And also makes stroker kits.
Old Aug 29, 2002 | 05:50 PM
ImportReview
Guest
Posts: n/a
Default Re: Toda vs. CTR vs. IB Spec Pistons (Tweety R)
New Z06 owns you huh?
We could change that pal. LOL For alot less than a Z06!
Jeff
Old Aug 29, 2002 | 05:54 PM
Eric R's Avatar
Jeff
Jeff, we also have to change the driver because I really suck on the road course
Old Aug 29, 2002 | 06:29 PM
Majuniors_no_vtecfu's Avatar
you cant let the z06 onw ur itr
Old Aug 29, 2002 | 08:31 PM
Maxi's Avatar
Default Re: Toda vs. CTR vs. IB Spec Pistons (Majuniors_no_vtecfu)
I ran Toda pistons in my B18C1 block but I melted two of them at the OTC when I spun all the crank bearings. They melted just below the top surface where the rings seat. They are really nicely constructed pistons, no doubt, but I wouldn't buy another set given the cost compared to other high quality pistons like Wiseco or Probe.
I used CTR pistons in my B16a block and I just blew the #4 piston up very nicely while road racing at Toronto Motorsport Park. Here are some pics...
Wreaked havoc in the combustion chamber too. Completely pancaked the spark plug, destroyed several valves, and of course completely seized the engine. I'm not sure if a forged piston would have survived any better or prevented some of the collateral damage but I won't be using CTR pistons again. Too many clearance issues if you're looking to run big compression and big cams.
If I build another high compression engine I was planning on going with Rollerwaves but I like the look of the IB pistons so I think I'll give them a try instead. If money was no object I'd consider the Todas again since I'm running Toda cams but for the money the Wiseco IB's look very nice IMO.
Old Aug 29, 2002 | 09:20 PM
Mike M's Avatar
Founding Member
Yup, I have them
Complete Toda Catalog Minus the ITB's in my car
As Far as compression #'s
Toda Will yeild 12.4:1
CTR Should be about 12.1:1
Toda's Forged Piston Set
Old Aug 29, 2002 | 09:46 PM
Big Phat R's Avatar
Default Re: Toda vs. CTR vs. IB Spec Pistons (TypeRmsm)
Yup, I have them
You damned JDM ricer!! dON't yoU reAliZe yoU're waSting YoUr MoNey??
Old Aug 29, 2002 | 09:53 PM
Mike M's Avatar
Founding Member
Default Re: Toda vs. CTR vs. IB Spec Pistons (Big Phat R)
hehe, If I didn't have a shop Half the stuff on my car wouldn't be there. Its More of a showcase of our products we sell
Old Aug 30, 2002 | 12:06 AM
sgT's Avatar
sgT
Ashame its a showcase you cant "show" to anyone.
Old Aug 30, 2002 | 06:09 AM
Black R's Avatar
25 Year Member
Yup, I have them
.....how do you like the seperate tank coilovers?
Old Aug 30, 2002 | 06:31 AM
Hooch'n's Avatar
Default Re: Toda vs. CTR vs. IB Spec Pistons (Black R)
.....That looks bad! $
Old Aug 30, 2002 | 08:43 AM
Mike M's Avatar
Founding Member
Default Re: Toda vs. CTR vs. IB Spec Pistons (sgT)
You know what I meant
Old Aug 30, 2002 | 12:07 PM
RICHJ's Avatar
Would CTR pistons in an ITR engine (giving 12:1 CR if I have read correctly) cope with JUN III/TODA B/Skunk2 II type cams?
Old Aug 30, 2002 | 12:12 PM
canuck-mx6's Avatar
Default Re: Toda vs. CTR vs. IB Spec Pistons (HardHead42)
Yes, they would, that is what I am running in my GSR block now. The thing is that there is not much valve/piston clearance, so you cannot do much camgear tuning.
Old Aug 30, 2002 | 12:18 PM
Black R's Avatar
25 Year Member
Default Re: Toda vs. CTR vs. IB Spec Pistons (Maxi)
.....wtf are you doing to keep going through pistons?
Running too lean + detonation?
Old Aug 30, 2002 | 12:32 PM
sgT's Avatar
sgT
Default Re: Toda vs. CTR vs. IB Spec Pistons (canuck-mx6)
Huh?? I had PLENTY of clearance. But you should always be smart and check.
Old Aug 30, 2002 | 12:41 PM
RICHJ's Avatar
how much degs on the gears did you have room for?
Old Aug 30, 2002 | 12:46 PM
sgT's Avatar
sgT
+- 10 or more i think. i ran with them set at +5 int and anywhere between -8 and -12 exh so....
Old Aug 30, 2002 | 12:49 PM
RICHJ's Avatar
Sorry should have asked which cams too.
Old Aug 30, 2002 | 12:51 PM
sgT's Avatar
sgT
Toda C
Old Aug 30, 2002 | 12:52 PM
RICHJ's Avatar
Thanks, very helpful
I feel a plan coming together.
[Modified by HardHead42, 9:55 PM 8/30/2002]
Old Aug 30, 2002 | 12:53 PM
sgT's Avatar
sgT
Like i said before, mine is just one instance, the next may not be anywhere close.
so its very important to check if you value your engine.
