Integra GSR stalling and having a rough start
Old Oct 19, 2009 | 11:37 AM
NosShootinHonda's Avatar
Default Integra GSR stalling and having a rough start
I have a 1997 Integra GSR, 160k miles. I just bought the car from a friend and it has a hard time starting up. I have to crank it for awhile and try a few times to get it started. But once I get it started, if I turn it off, and try to start it again, it will start easier. The car also stalls or "bogs" down when I gas it all the way. It feels like it wants to die. So far I have tried:
new NGK spark plugs
new spark plug wires
new battery
The car does not have a CEL. Any input would be appreciated, thanks!
Old Oct 19, 2009 | 11:54 AM
eaglewesman's Avatar
Default Re: Integra GSR stalling and having a rough start
I would check your timing first (it's easy), should be 16 +/- 2 BTDC but check your manual to make sure. Sounds like a fuel/air ratio problem - so could be a variety of things. O2 sensor, ECU. Maybe check your distributor; coil, ignitor, etc.
Old Oct 19, 2009 | 06:28 PM
I am using a jdm p72 ecu. I'm not sure if that could be causing the problem. The original usdm p72 got stolen. But I'll check the timing. Thanks
Old Oct 26, 2010 | 07:31 PM
TakeItTo8K's Avatar
I have a similar problem, almost same symptoms, yet I have a CEL for an O2 sensor, im going to try an replace it and see what happens.
Old Oct 26, 2010 | 07:48 PM
Acura_DreamiN's Avatar
my last integra had issues starting sometimes, it was due to main switch reply though..i took it in for a diagnosis...
the bogging issue though, my new GSR has issues to and i'm still working on that one....sigh. . . .
Old Oct 27, 2010 | 06:36 AM
JPhilBradley's Avatar
I'm having this same problem; looking forward to seeing where this thread goes.
Old Oct 27, 2010 | 07:13 AM
JPaesch's Avatar
check and clean your throttle body sensors..
ohhsoogood
Oct 13, 2013 04:17 AM
mwpowers
Dec 19, 2008 06:21 PM
Jizzo
Jun 5, 2008 06:54 PM
timisyourfriend
Feb 8, 2007 09:41 AM
Master23
Aug 7, 2004 11:25 AM
