EGR valve code
Old Oct 19, 2009 | 07:30 AM
superdelsol's Avatar
Icon6 EGR valve code
ok so i'm getting the EGR valve code (p0401) on a 00 prelude. that's not really a big problem. i cheked the valve it's in good condition (vacume test) and i cleaned it up real good and still getting the code. that only means the sensor itself or the selenoid is defective. what voltages should i look for for proper working sensor and selenoid? i know the sensor comes as a full unit with the valve but is there a way to just replace the sensor if that's all that is wrong?
thanks
Old Oct 19, 2009 | 04:17 PM
KWayRacing's Avatar
Default Re: EGR valve code
Probably the ports are stopped up. Need cleaning, but this can be a major task on preludes if the ports are cast over instead of freeze plugged into the IM which most of the later ludes were.
Old Oct 19, 2009 | 04:23 PM
night's Avatar
ya if you can tell us or get a pic of the port caps we can give you the process needed
s2000 mf
Oct 30, 2004 06:37 PM
gsrcivict
Oct 14, 2003 04:51 PM
dchi_t
Mar 13, 2003 04:52 PM
