97 CL jdm engine question
doing a swap in a swap in a 97 CL soon and curious what the details
http://cgi.ebay.com/ebaymotors/Accor...#ht_3747wt_939
is one i found. however the stock engine is a f22b1 and this is a f22b, if this is kind of like the teg where the 1 just goes away in jdm land, no biggie. however, what's needed to make this work with obd2?
the same engine is listed for the accord 94-97. if it's simply a distributor swap it shouldn't be too tough. i know in the b18c you need a cfs sensor to run the usdm ecu. if anyone has used a jdm replacement motor in an obd2 CL i would love to hear the skinny
lastly, are the auto trans units from the SOHC f22b vtec the same as the f22b1 used in the usdm 97 cl?
b18cKoupe
Acura TL, RL & ZDX
Mar 25, 2010 08:59 PM
