spindle on tranny wont go in
Old Oct 18, 2009 | 06:49 PM
acuralovar's Avatar
Default spindle on tranny wont go in
ok i have a 92 integra i just did the clutch on it last december with no problem yesterday i went to do another clutch everything was goin fine. i go to put up the tranny and the spindle does not want to go on..ive tried everything .. i have even tryed putting bolts in the bell housing to pull the tranny into the motor and nothing wont budge.. the clutch is from a 91 integra but i dont think it makes a difference because the alignment tool fits perfect in the clutch i just took out..i just did this last year and it wasnt bad . can anyone give me any advice?
Old Oct 18, 2009 | 07:04 PM
bigislandc2's Avatar
Default Re: spindle on tranny wont go in
the disc on the 90-91 discs are smaller you need to use 92 and up clutch. unless you use a 90-91 trans or swap over the main shaft from an older trans.
Old Oct 18, 2009 | 07:14 PM
Import_spoon's Avatar
yes bigislanddc2 is correct 90-91 spindles are different from the 92-93. You will need a 92-93 clutch. I'm pretty sure you can get away with 94+ Integra clutchs also.
hondatuner20
11
Mar 21, 2006 05:40 PM
baked_beanz
Sep 14, 2005 10:48 AM
blacksi_r
Jan 13, 2004 12:52 AM
