H22 OBDII swap people, have an ECU question for you
Old Oct 18, 2009 | 03:57 PM
RPM JDM's Avatar
Default H22 OBDII swap people, have an ECU question for you
For the people that have swapped an H22 into their 96 or newer Accords, were you able to run the factory ECU and have the engine work without and CEL light? I'm thinking of doing the swap on my 97 but I live in VA where there is a plug in emissions test where they plug it into the OBDII port, if you don't have a CEL light on it passes.
Any help or info you guys have on this would be appreciated, thanks.
Old Oct 18, 2009 | 04:30 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: H22 OBDII swap people, have an ECU question for you
We have a plug in emissions test? You must be Northern VA... I think they do.
You need the OBDII P13 ecu - only one that's OBDII without an immobilizer. If you run an OBDI ECU you won't have a CEL (if everything is fine) but the OBDII port will report no communication - that was enough for the buyer of my car to register in Arizona (similar testing).
I'd imagine running the stock ecu would run you in limp mode but I"m unsure on having a CEL.
Old Oct 18, 2009 | 04:53 PM
v4lu3s's Avatar
RTFM
1996 honda prelude vtec ecu is what you need. it is the ONLY obd2 p13 and the immobilizer was on the 97+ ecu. its a very rare ecu.
Old Oct 21, 2009 | 08:08 PM
drew1987's Avatar
ya,what they said...i actually got lucky and found one on craigslist for $200 from this chick...
Old Nov 13, 2009 | 04:17 PM
h22apwrdcivic's Avatar
would it pass with a 96 p14 ecu, granted it wont have vtec but just curious b/c i found one on craigslist for $50.
ZCHondaCRX91
Honda CR-V & Element
10
Oct 30, 2014 06:21 PM
import_tuner13
Nov 12, 2011 01:03 AM
japscrap
Feb 17, 2009 03:29 AM
hotrodaccord
Dec 31, 2007 03:26 AM
6GACCORDH22
Feb 1, 2003 10:21 AM
