Lighting HID/Xenon kits, Retrofits and Associated Topics
HID install, 1 headlight not working 96 civic.
Old Oct 18, 2009 | 02:15 PM
BokudenNYC's Avatar
Default HID install, 1 headlight not working 96 civic.
Prior to install, the passenger side headlight seemed a bit dim. After install, the passenger side headlight doesn't even work. The driver side is fine. I switched bulbs and ballasts to make sure it just wasn't bad hardware. But everything checked out fine. The 3 prong connector from the wire harness that connects to that passenger side headlight isn't stock though, it's a cheapy looking aftermarket plug. Maybe that's the problem?
Old Oct 21, 2009 | 01:43 AM
likwid2u's Avatar
Default Re: HID install, 1 headlight not working 96 civic.
some times hids need to be hooked up to highbeams only and wont work on low
Old Oct 25, 2009 | 11:28 AM
BokudenNYC's Avatar
The problem turned out to be the aftermarket plug. I went to a junkyard and clipped an oem plug, installed it and the HID worked fine.
got00rice
Nov 23, 2009 05:28 PM
J.nguyen
Honda S2000
Aug 13, 2007 11:44 PM
jsrdelsol
Dec 3, 2005 09:02 PM
Grimm
Sep 4, 2003 06:43 PM
