what bearings for a built set up?
Old Oct 18, 2009 | 10:52 AM
94eh2's Avatar
Default what bearings for a built set up?
im currently building a gsr bottom end with eagle h beam rods, wiseco pistons and a ITR crank. which would be the correct OEM bearings to get? because honda has all sort of different colors for each different clearence. can anyone direct me in the correct way??
Old Oct 18, 2009 | 05:35 PM
94eh2's Avatar
Default Re: what bearings for a built set up?
bumpp
Old Oct 18, 2009 | 07:38 PM
fortillian's Avatar
Also looking to build a bottom end, would like this info as well.
Old Oct 18, 2009 | 08:24 PM
jayWknight's Avatar
You engine builder can tell you which ones. Since you are using a different a crank, you need to have everything measure to make sure they are in spec.
Old Oct 18, 2009 | 08:44 PM
R666_EK's Avatar
Yeah, you need to have each journal mic'd. A machine shop can let you know.
Old Oct 18, 2009 | 09:20 PM
civic_r87111's Avatar
Ok this must not b common knowledge so.. the ITR and GSR cranks, rods, and blocks r exactly the same. So u can use ACL GSR bearings or decode the block/crank bearing code and use OEM honda bearings or u could use Clevites for a GSR or Type R or whatever u preffer. I like the ACL race and OEM honda myself.
Old Oct 19, 2009 | 11:52 AM
94eh2's Avatar
ye never mind i got it..im using OEM bearings. i got the chart that determines witch is witch.
bswapsedan
May 21, 2015 12:28 PM
salyboy25
10
Jul 19, 2011 12:38 AM
NADC4
Jun 25, 2007 11:23 AM
Si2See
Jan 17, 2007 04:51 PM
TRuST
Mar 2, 2002 07:53 PM
