Type R Clutch Failures
Old Aug 29, 2002 | 03:21 PM
hecklervtec's Avatar
From: Formerly WI, now back in NorCal and everywhere else
Default Type R Clutch Failures
After the experiences I had when my clutch failed recently, I'm writing Acura. Here's a link if you want to read about it.
https://honda-tech.com/zerothread?id=214560
In short:
David and Mike Harvey Acura
Acura of Serramonte and Acura Customer Care
I'm trying to get an idea of how many others have had similar clutch failures. Those of you who have had clutches fail prematurely, could you please post what failed and at approximately what mileage it failed at.
Also, can someone confirm if the stock clutch/pressure plate in the Type R is the same as the GSR and LS/GS? I'm getting two different stories. Thanks in advance.
Old Aug 29, 2002 | 03:36 PM
NINJA's Avatar
Default Re: Type R Clutch Failures (hecklervtec)
My clutch won’t shut up!!!
I'm at 69,000 Km but it started at around 65,000.
The sound comes from the drivers side so I doubt it's the release bearing. It sounds as if it it's coming from the actual pedal and/or the master cylinder.
Any insight would be appreciated.
Old Aug 29, 2002 | 03:58 PM
Austin's Avatar
Default Re: Type R Clutch Failures (NINJA)
At 20,000 miles I have issues with the clutch...doesn't engage correctly, however it still holds without an issue...the local dealership is a bunch of yahoos that I don't care to have working on my car, other than that the closest dealership would be ~1.5 hours, I'm going to change the clutch out by myself...
Austin
Old Aug 29, 2002 | 05:05 PM
JohnnyBoy's Avatar
Default Re: Type R Clutch Failures (Austin)
I got 110,000 km on mine before it finally broke. I thought it was pretty good. Still held strong too, just the spring retainer broke on the disk....
Old Aug 29, 2002 | 05:30 PM
D's Avatar
D
65k miles a clutch spring broke... friction surface was still in decent shape.
D
Old Aug 29, 2002 | 05:57 PM
MrBite's Avatar
Default Re: Type R Clutch Failures (D)
Right about 61,000 for my GS-R, identical to the pic in that thread you linked to.
Old Aug 29, 2002 | 07:27 PM
jmb's Avatar
jmb
Default Re: Type R Clutch Failures (MrBite)
I have 81k on the original clutch. It still works.
Old Aug 29, 2002 | 08:51 PM
SoCal ITR's Avatar
Default Re: Type R Clutch Failures (jmb)
24,500 miles and my clutch is acting up, it doesn't enguage properly all of the time. From what I hear, it's the pressure plate springs. I'll get it fixed when I get back.
Old Aug 30, 2002 | 08:11 AM
Default Re: Type R Clutch Failures (SoCal ITR)
Anyone else?
Old Aug 30, 2002 | 08:21 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
8100 miles and 2.5 bottles of Nitrous - FAILED
Old Aug 30, 2002 | 08:26 AM
Nick248's Avatar
At 35,000 miles, Acura replaced my clutch at the same time the replaced my motor.
The newer clutch only lasted 25,000 miles of very easy driving. (Not track events, no autoX's or strip events) The pressure place spring broke.
It shouldn't have failed at 25,000 miles.
-Nick
Old Aug 30, 2002 | 08:53 AM
norice's Avatar
Default Re: Type R Clutch Failures (Nick248)
I upgraded my clutch after 20k miles of hard driving and the disc was still within new specs according to the Helms.
Old Aug 30, 2002 | 08:54 AM
ITR764's Avatar
mine was replaced at arund 20k because of a very loud release bearing. brand new clutch assembly and they even put a TODA fw while they were in there!!!
to my local acura dealer!!!!!!
Old Aug 30, 2002 | 09:02 AM
98itR484's Avatar
Default Re: Type R Clutch Failures (ITR764)
32k on my clutch, it still works, but i can feel it giving up.
Old Aug 30, 2002 | 09:37 AM
whiteGSR's Avatar
Default Re: Type R Clutch Failures (98itR484)
does anyone have an '01 clutch that experienced the same thing?
my gsr clutch broke a tooth in the pressure plate and experienced that same problems u descriped, but then again, i had 150K KM's
Old Aug 30, 2002 | 10:07 AM
SoCal ITR's Avatar
-Nick
Sounds like the same thing that is happening to me.
Old Aug 30, 2002 | 11:21 AM
Haunt's Avatar
Default Re: Type R Clutch Failures (whiteGSR)
I do, but I didnt brake a tooth, I broke a spring on the pressure plate. From what I remember it was around 23K milles that mine broke. I could barely get it moving b/c I couldnt shift when the car was on, so I drove to my local acura in 2nd gear (about 7 miles) :Shrugs:
However, Acura did replace my clutch under warranty without a problem.
I'm starting to think that Honda clutches suck a$$.
I forgot to add...that I have never drag raced or autocrossed my Type R.
Tom
[Modified by Haunt, 3:23 PM 8/30/2002]
Old Aug 30, 2002 | 11:30 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I'm at 43,000mi with around 90-110 drag launches and three auto-x events not to mention I use to drive the crap out of it back in my mad street racing dayz.
My clutch guage has always been my glove box which use to pop open on every 1-2 shift. Now its just sits there all nice and closed up. I kinda miss reaching over to shut it during 3rd gear at the strip. My manual is getting all lonely too since he use to come out and scare unsuspecting passengers. He sure was a prankster, but now I rarely see him unless I'm getting my tire pressure guage. Ah the good ole days .
Old Aug 30, 2002 | 11:39 AM
Black R's Avatar
25 Year Member
D
Man, and I was sure D was gonna say "IT'S A WEAR ITEM! n0b!"
Old Aug 30, 2002 | 11:41 AM
acuracy389's Avatar
New User
Default Re: Type R Clutch Failures (ActiveAero Ninja Edition)
I had a problem with my OEM clutch on my '98 ITR @ 42,000 miles. I was driving back from Carlisle PA to NOVA and I went to downshift from 5th to 4th. It wouldn't go into gear, so I tried 3rd...still didn't go. I barely got it back into 5th. Ended up driving back to the dealer in 5th (which sucked). They called me to let me know my clutch was shot and my flywheel was cracked in half?! Whatever. I now have an ACT and a Fidanza (which I am not satisfied with b/c of of chatter problems, but thats a whole different story...)
-Heather
Old Sep 5, 2002 | 06:02 AM
MackSpeed-616's Avatar
Default Re: Type R Clutch Failures (acuracy389)
-Heather
At 42k miles i'm on my 4th motor and 3rd clutch.
Old Sep 5, 2002 | 06:45 AM
JPP's Avatar
JPP
Default Re: Type R Clutch Failures (BustaNutt-616)
I am at 84000 KM and the clutch is starting to give signs of failure in a not to distant future. Gears won't engage properly, need to give more gas to go from a stand still... I am waiting for an new Exedy clutch so I can give a new life to the car (with the help of a ATS FD and lighter FW)
Old Sep 5, 2002 | 08:45 AM
gblaue's Avatar
Default Re: Type R Clutch Failures (JPP)
2 bad pressure plates replaced before 25k miles.
Old Sep 10, 2002 | 04:51 AM
Haunt's Avatar
Default Re: Type R Clutch Failures (00ITR#756)
ouch!
Old Sep 10, 2002 | 05:19 AM
Keane Rated R's Avatar
Default Re: Type R Clutch Failures (Haunt)
75k km of hard driving.. still on stock clutch.. gearbox and LSD went KAABOOOOM on c.a. 35k km´s
