Violent shaking @ 60+ MPH on FWY
Old Oct 17, 2009 | 08:04 PM
ieatrice's Avatar
Default Violent shaking @ 60+ MPH on FWY
i have an unsual problem in my 96 civic hatch. it drives fine until i go on the fwy. if i accelerate past 60, the whole front end feels like it's shaking violently - dash, steering wheel, left/right tires, but if the speed drops under 50mph, it's fine. WTF?! i checked to see if my lugnuts are loose, but they're on tight. it's too dark to take a look underneath my car, but what's likely the problem so i get an idea? any help would be greatly appreciated. thanks!
Old Oct 17, 2009 | 08:13 PM
pliskin679's Avatar
Default Re: Violent shaking @ 60+ MPH on FWY
i have the same problem if i hit 80 and drop to 70 lol, i think it might be a shot axle, i know for a fact that my passanger side axle is done for, and the bushings are bad. thats just my 2 cents, i could be completly wrong though.
Old Oct 17, 2009 | 08:19 PM
acake em1's Avatar
Colonel Cake Mix
axles you usually feel when u accelerate and not at specific speeds. I had this problem and my motor mounts were bad, and i also had some bad ball joints
Old Oct 17, 2009 | 10:19 PM
raidacaipo's Avatar
same thing for me buddy.. I still cant fix it.. im doomed for life
Old Oct 18, 2009 | 12:04 AM
gilbert90605's Avatar
go get your tires balanced..
Old Oct 18, 2009 | 01:28 AM
bluebomber's Avatar
Information Leafblower
Are your tires going bad? When was the last time you had an alignment? Are your motor mounts in good condition? These are the first things I would check, in that order.
Old Oct 18, 2009 | 03:18 AM
NFrank89's Avatar
yeah check the wear pattern on your tires for alignment issues and see if your tires need balancing. i have the same problem at 70 but 60 is fine.
Old Oct 18, 2009 | 03:49 AM
CarGuy75's Avatar
Check your outer tie rods also. 10mph window of shaking usually means an outer tie rod problem.
Old Oct 18, 2009 | 06:31 AM
mark pones's Avatar
yeah do whats been said above, also you should check your ball joints to see what kind of condition they are in.
Old Oct 18, 2009 | 07:12 AM
D'sEk9's Avatar
x2..............
octaneaccord02
May 17, 2009 11:28 AM
BoltonGSR
Apr 3, 2009 06:15 AM
92ehatch
Aug 19, 2005 11:20 AM
xxxmikenicexxx
Feb 15, 2004 07:27 PM
RotiEatter
Aug 12, 2003 12:55 AM
