Windows moving slowly....
Old Aug 29, 2002 | 02:53 PM
brownman72000's Avatar
Default Windows moving slowly....
I know this topic had already come up but there wasnt too much feedback about it. My windows move up really slowly and they dont move down as fast as they should either. It seems like the best things for that are the lithium grease and the tri flow teflon based spray. Do they both work effecttively? Where can I get some of that from? Also, how much should be used and what needs to be sprayed beside the track, anything?
Could this problem also be worn down motor mounts? My car has 90k on it so I would be surprised if it were but any suggestions? Thanks!
Old Aug 29, 2002 | 03:01 PM
yoshi234's Avatar
I shoot brides
Default Re: Windows moving slowly.... (brownman72000)
there's an LA Times article about power windows here
Old Aug 29, 2002 | 03:21 PM
Big Phat R's Avatar
Probably a few reasons for this:
1) small lightweight window motors that don't have a lot of power to begin with (probably done on purpose for weight reasons)
2) a weak alternator that supplies only nominal power to accessories (this tendency is found in all Honda cars)
3) a weak small battery - a Type R exclusive
Correct the above and your windows will operate more quickly.
I say if they still move the windows - leave them be.
Old Aug 29, 2002 | 03:26 PM
DaRKniGhT ITR's Avatar
Default Re: Windows moving slowly.... (Big Phat R)
Yeap i have the same problem in mine when it was normal...when i bought the JDM ITR c/f switches it made one go up faster...but the other slower...go figure
Old Aug 29, 2002 | 04:08 PM
Austin's Avatar
Default Re: Windows moving slowly.... (DaRKniGhT ITR)
Could be that the tracks need a lube job
Old Aug 29, 2002 | 05:52 PM
jond's Avatar
I heard this is a recall item or something like that.
I think Acura will fix it for free.
Old Aug 29, 2002 | 06:43 PM
RealTypeR2's Avatar
Use Honda/acura Silicone spray.. works wonders. ]
If it still moves slowly, then more than likely something is binding making the iwndow go slowly and the motor working harder than before.
Old Aug 29, 2002 | 08:01 PM
py1188's Avatar
Default Re: Windows moving slowly.... (RealTypeR2)
I've just learned to live with it, would be interesting if it was a recall though
Old Aug 29, 2002 | 10:21 PM
Default Re: Windows moving slowly.... (py1188)
Honda silicon spray huh? ..Hmmm im going to check into that one....the tracks might need to be "lubed" up..
Old Aug 29, 2002 | 11:38 PM
Ch33se's Avatar
New User
if you lub the tracks wouldnt the lube get on the window everytime you roll up and down?
Old Aug 30, 2002 | 01:37 AM
:jdmshmaydm:'s Avatar
That's kinda fishy. My window goes up slowly as well. I think I notice it mostly on the passenger side of my car. OH by the way I drive a 2000 GS-R. I rode in my friend's 95 GS-R and they were pretty speedy on the roll up. It doesn't bother me though, just thought I'd say I can relate.
Old Aug 30, 2002 | 08:58 AM
schumiR's Avatar
Yep, mine too.
Old Aug 30, 2002 | 11:27 AM
aet6's Avatar
Default Re: Windows moving slowly.... (schumiR)
the recall was for window motors that were making some kind of noise if i remember right
like a clunking noise when u first start rolling up/down, which mine has, i just never cared.
aet
wizarddrummer
Sep 4, 2012 10:44 AM
AiL45
Honda Civic (2001 - 2005)
Aug 14, 2006 05:45 AM
wizurd
Feb 11, 2002 05:37 PM
