1996 HONDA LX Clutch??
Old Oct 17, 2009 | 03:41 PM
new4me's Avatar
Default 1996 HONDA LX Clutch??
I guys/girls..
I have a 96 honda civic lx my car drives fine and runs good however it has 280,000 kms on it. This is my problem when shifting the car in any gear the car seems jump ever time you hit the gas ....(Kind of hard to explain) what would this be from ? maybe a worn out clutch?
Please help any info would be great !
Old Oct 18, 2009 | 07:47 AM
new4me's Avatar
Default Re: 1996 HONDA LX Clutch??
Anything??????
Old Oct 18, 2009 | 10:10 AM
boxeocampeon's Avatar
well if the clutch was worn out it would cause the clutch to slip and the car to rev like you are in nuetral. misfire will be more like it bogs down and then frees up
Old Oct 18, 2009 | 10:32 AM
new4me's Avatar
I know the clutch has never been replaced.... so I was told anyway and the car has lots of power it dont really bog out.
let me try and explain it this way , when driving my car in 2nd gear with low rpm's( 2,500- 3,000) if I were to press on the gas the car jumps!! even when barely touching the gas, this happens in 3rd gear 4th gear and 5th gear what could this be from ?
Old Oct 18, 2009 | 01:54 PM
patrickvertigo's Avatar
Is this happening when you are completely off the gas pedal and just try to feather back on the gas? After you get back on the gas, is it kinda jerky for a second too? Last question, is it more sensitive when you are in a lower gear (ex. 1st or 2nd) than if you are in 5th?
My car does the same thing. I believe the jumpiness (I think this is a word) is from play in the engine mounts. Your engine actually will tilt slightly back and forth depending if you are decelerating or accelerating. All cars have some play, and depending on how many miles are on your car, it could be more or less. Let me know if this is what you are experiencing. As for a fix, unless the jumpiness is really terrible and your engine mounts are in really tough shape, I probably wouldn't do anything about it.
Hopefully this info has helped.
Old Oct 18, 2009 | 02:13 PM
new4me's Avatar
Yes this is exactly what its doing
after you get back on the gas, is it kinda jerky for a second too? Last question, is it more sensitive when you are in a lower gear (ex. 1st or 2nd) than if you are in 5th?
yes then drives fine it does this in all gears
Ok if this were the case would'nt the car do this out of gear too?.. Cause my car dont
Old Oct 18, 2009 | 05:07 PM
You won't feel it through the wheels when it is out of gear. If you were to have somebody blip the throttle with your car out of gear with the hood open. You would see the engine tilt slightly. It does this while the car is in gear or not, but when it is not in gear you will not feel the jerk. Does that make sense?
It is annoying when it happens and my car has about 212K on it (it is also a 96 civic LX). I have had it about three years and bought it with 153K. I haven't really noticed it get any worse in that time. Maybe slightly if any. All five speeds do it, but it is more noticeable with a front-wheel drive car than a rear-wheel drive car in my experience.
I'm not sure if getting new or stiffer engine mounts would help it any. Maybe somebody else would have information about that. It would be kinda neat to figure that out.
Old Oct 18, 2009 | 05:17 PM
new4me's Avatar
Well thanks for your help... I will get the motor mounts looked at tomorrow
Old Oct 18, 2009 | 05:24 PM
I didn't say go out and buy motor mounts. You could give them a look though. I think there are three main mounts one on each side of the motor and one on the back. If the rubber bushings that are inside the mounts are deteriorated terribly that might help to get them replaced. But I do not know how much improvement you will see from replacing them. By spec, the engine is supposed to have a little play. This is so that you don't end up breaking anything. I think if you were to get aftermarket performance mounts, it would stiffen up the motor a little bit, but I haven't done any research on this or the cost.
Old Oct 18, 2009 | 09:23 PM
i personally think its misfire
Old Oct 19, 2009 | 06:04 AM
new4me's Avatar
Yeah. but if it were a miss fire wouldnt the car bog out ? how would iget this checked
Old Oct 19, 2009 | 10:33 AM
are you pulling any CEL?
Old Oct 19, 2009 | 04:16 PM
new4me's Avatar
The only CEL that Im getting is the Secondary oxygen sensor heater.
Old Oct 19, 2009 | 04:43 PM
replace that and see what happens i was having major misfire when my o2 sensor was bad.
Old Oct 19, 2009 | 06:21 PM
R666_EK's Avatar
A missfire WILL NOT cause it to jump as the OP describes. It will bog down like crazy. And you will most likely hear it.
I'm leaning towards mounts as well. But you should still get the o2 sensor replaced.
Old Oct 19, 2009 | 07:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The secondary O2 sensor is just a monitor. It has NO bearing on how the car runs.
I'm not sure what you mean by "jumps", though, OP.
It might be mounts. Take a look at your driver's side upper engine mount. It is located near the shock tower. That mount is liquid filled and is VERY prone to breaking on 96-00 civics.
Old Oct 19, 2009 | 09:52 PM
yeah ur probably right
Old Oct 20, 2009 | 04:27 PM
new4me's Avatar
yeah I know Im not doing a good job telling you whats going on with my car.
To be honest it really hard to describe what going on with my car.
I will change the o2 sensor its not alot of money, as for the motor mount is there anyway to tell if its broken just by looking at it ?
Old Oct 20, 2009 | 07:13 PM
B serious's Avatar
^^ you can tell if the mount is broken by looking at it by following these steps:
Look at it.
If it's torn and there's oil everywhere, it's broken.
The 02 sensor is probably cheap. www.sparkplugs.com has OEM O2 sensors for cheap.
Old Oct 20, 2009 | 09:48 PM
tho o2 sensors gonna be like 150 bucks
Old Oct 20, 2009 | 09:55 PM
B serious's Avatar
ORLY??
$150...$43...same thing.
ED9
13
Nov 26, 2010 06:29 PM
ac_attak
Sep 5, 2008 09:53 AM
92civicSIHatch
Sep 21, 2003 02:46 PM
brucie
Jul 12, 2003 11:23 AM
civicheaven151
17
Jul 6, 2002 07:25 PM
