EK hatch with power windows and locks?
What would I need to make it work?? Will I need both door shells or can i just get the door panels and all the wiring for it? I know I will need the dash wiring harness. I know this topic has been covered but still confused. Thanks
si door panels, or ek 2dr, power window assembly, heard its a big pain in the ***
Youll need to get the panels from any car that has the same doors as you with pw/pl (96-00 coupe/si). Youll also need to find a ditionary of cuss words cause youll definately run out. Its definately a huge PITA. I personally wish I still had crank windows.
y do u wish you still had crank windows?
perhaps there are aftermarket kits that are better and easier to install?
Miguel
Bingo!! I used a Spal kit from Ebay which cost around $80. I hooked it up to the factory swicthes and it works beautifully!! and, if you are seriously concerned with weight, it it MUCH lighter than stock power window regulators.
Miguel
Miguel
ja20_eg
Oct 4, 2011 10:02 AM
