K20A3 valvetrain
I have been doing some research and I was interested in replacing my valve springs to dual springs and my retainers to titanium ones. Then I would send in my my ECU to Hondata and have the redline raised to 7700 rpm. Would this be safe?
unless you are using some beefy cams no needs for the titanium springs and retainers. If you are using factory cams you can swap springs/retainers with the Z1/Z3 and you can up redline but just make sure it's worth it power wise. I'm not sure what the power drop off on your setup is. Ever dyno your car?
NC-B17A
21
Feb 26, 2004 05:40 PM
