Suspension & Brakes Theory, alignment, spring rates....
skunk2 lower control arm Installation
Old Oct 16, 2009 | 08:58 PM
hondasingapore's Avatar
Default skunk2 lower control arm Installation
hi, guys:
Anyone can help me to explain in detail on the proper installation instruction of Skunk2 Lower Control Arm? I do a count, there is 10 mounting holes (3 smaller ones in the middle, what are they for?)?
On the right as in the url below, there is 3 mounting holes, they are for bolting on the coilover. Can someone explain to me, what difference will it make to the suspension if I change the mounting hole from 1 to the other? What about the 3 mounting holes on the LEFT?
http://www.boombopracing.com/ebay/pi...2/s2-lca-1.jpg
Thanks.
Old Oct 16, 2009 | 09:51 PM
dandaman15's Avatar
Community Builder
Default Re: skunk2 lower control arm Installation
The only holes you use are the ones with the bushings in them. The others are just there for looks and to decrease weight.
Old Oct 17, 2009 | 07:15 AM
hi:
Thank.
Someone also told me that the middle 3 holes are for the mounting of anti-roll bar using the endlink.
Can someone please help as I am sure skunk2 LCArm is very common with you guys?
Old Oct 17, 2009 | 07:48 AM
K20egcw's Avatar
Damn, how can you not figure out how to swap LCA's? Look at the one on the car and put it back exactly how you've taken the old one off, simple! The 3 little holes are for swaybar endlinks
Old Oct 17, 2009 | 01:49 PM
STOCK_SOHC_DX's Avatar
What?
I'm pretty shure the smaller holes are for your sway bar(end links) mounting holes.
Old Oct 17, 2009 | 02:54 PM
dandaman15's Avatar
Community Builder
Originally Posted by STOCK_SOHC_DX
What?
should have been more specific
Old Oct 19, 2009 | 10:57 AM
a97b18b's Avatar
I thought he meant those holes too. For the 3 end link holes...those are for soft/med/hard correct?
Old Nov 11, 2009 | 10:55 AM
Cnile1's Avatar
WOW People! The three threaded holes are for the sway bar endlink to bolt on to.
Old Dec 15, 2013 | 10:55 AM
EJ25er's Avatar
so do you need to replace the sub frame on a gsr for ITR sway bar? or can you use the LCA ?
Old Dec 15, 2013 | 12:43 PM
aw614's Avatar
10 Year Member
Loved
you can use stock lca with an asr brace on a gsr/ls with itr sway bar
Old Dec 15, 2013 | 01:09 PM
EJ25er's Avatar
I'll prob pick up a brace anyways, but have the s2 lca's just curious if I need to upgrade sub frame still
hondasingapore
Suspension & Brakes
Oct 15, 2009 01:14 PM
JHPUSA
17
Jun 30, 2009 08:49 AM
PatrickGSR94
Suspension & Brakes
19
Jul 30, 2007 03:43 PM
EnjoyTheRideDC2
Jan 10, 2007 10:36 PM
.RJ
Mid-Atlantic (Sales)
Dec 9, 2005 05:42 AM
