idoling problems . ( check engine light ) !!!
ok so i just dropped a new D17A2 in the 02 EX & it has ZERO miles on it. when i did the first start up it was perfectly fine with NO check engine light but it was already idoling weird. the way it idols is that when i drive it its fine but then right after i stop, it starts to idol at 2,000 rpms for like 5 seconds then it stops & idols normal & thats not normal. & the engine light never came on, so today the motor just made about 35 miles into it & i went on the highway for the first time w. the new motor & the engine light came on & i have no idea why & when i stop it still idols at 2 grand . so if you get what im talkin about please help me w. this problem . thanks .
Take it to Autozone or whatever auto store near u, and have the CEL scanned for free. Itll tell you where to start...
Other than that, if u come to a stop and the idle goes up to or fluctuates around 2k, then drops down to a solid idle around 500-700... should be normal. At least mine does it, they are supposed to idle low because of the ULEV.
no but i think i found the problem, should be the IACV . im just gonna replace my old one from my old motor with my new one cause the new motor is from the auto motor & it has a different number on it. thanks .
bassrocker521
Feb 20, 2008 05:51 PM
