Accords low or high compression?
Old Oct 16, 2009 | 03:43 PM
02AccordSE's Avatar
Default Accords low or high compression?
I just read on a different forum that the 98-02 accord 4cyl have low compression engines which make the prime for turbos and NOS. I always thought my accord was high compression which makes them difficult to add turbos.
Does anyone else know if they are high or low?
Old Oct 16, 2009 | 04:07 PM
ferio252's Avatar
Default Re: Accords low or high compression?
The 98-02 Accord's had a compression ratio of 8.8:1 or 9.3:1. In term's of adding boost, I don't know if that's a good or bad thing. Bump for someone with more excperience.
Old Oct 16, 2009 | 05:13 PM
GhostAccord's Avatar
Anything under 10:1 is definitely low compression. 8.8:1 & 9.3:1 are compression ratios that are definitely suitable for boost. There are a few other things to take into consideration when thinking about boost other than compression ratio. Strength of the engine and it's internals being two of the more important ones.
Old Oct 16, 2009 | 06:36 PM
P_Adams's Avatar
Low compression (as Ghostaccord mentioned). With the exception of the H series, most all Honda engines have moderate compression ratios.
P
Old Oct 16, 2009 | 08:06 PM
ferio252's Avatar
^ LoL. Diabeetus
Old Oct 16, 2009 | 09:40 PM
02AccordSE's Avatar
Sweet so my f series can handle a turbo mod.
Old Oct 17, 2009 | 10:01 AM
P_Adams's Avatar
It's generally accepted that F22's can tolerate 7 to 8 pounds boost on stock internals.
That may not seem like much, but it will be enough to get you around that snotty kid in the v6 Nissan
P
white2draccord
Apr 28, 2008 03:26 AM
TehMoonRulz
May 16, 2005 01:15 PM
90da4dr
Nov 3, 2002 09:10 AM
98civicEX
Jul 31, 2002 07:16 PM
