97 Civic squealing When put in 5th Gear
Old Oct 16, 2009 | 03:13 PM
odidipissuoff's Avatar
Icon6 97 Civic squealing When put in 5th Gear
Okay so i was driving to class the other day and I noticed that When I shifted into 5th gear the car began to squeal/whin. I added Honda Manual Transmission fluid, and still it squeal. What could be causing this? Is 5th gear shot? Flywheel Going out? or Cluth going out?
Thanks
Old Oct 16, 2009 | 03:22 PM
ferio252's Avatar
Default Re: 97 Civic squealing When put in 5th Gear
Noise that occurs only while driving or in a certain gear usually indicates a gear or bearing problem inside the transmission.
Does it happen while you're engaging or after you've engaged the gear (or both?)
Old Oct 16, 2009 | 03:24 PM
It starts to squeal after i release the cluth, but when i press the gas the sound weakens, but when i release the gas it becomes loud again.
Old Oct 16, 2009 | 03:55 PM
ttt
Old Oct 18, 2009 | 03:26 PM
Could this be coming from the Differential Gear?
Old Oct 18, 2009 | 05:13 PM
gwl's Avatar
gwl
Maybe your clutch is slipping?
Old Oct 19, 2009 | 08:45 AM
It still drive and accelerates like normal, but the noise is slightly annoying and don't want a small problem to become a HUGE problem.
odidipissuoff
Transmission & Drivetrain
18
Oct 27, 2009 06:17 PM
!moops vs moors!
Apr 13, 2007 08:47 PM
HONDA_TEG
Apr 21, 2005 10:47 AM
Mires
Sep 20, 2002 01:17 PM
