My Drag ITR - 1000whp inside.
Well, I'm a relatively new member on this site, but I figured since I'm into drag racing, I'd post my car up. A couple of them are a bit older, but the most recent are the ones with the front mounted SC-72. It's not 100% together at the moment, just got done pulling it apart and putting it back together. So excuse the mess of plug wires.
Mods:
Darton Sleeved 85mm LS block
9.5:1 Custom JE pistons w/ thicker wrist pins
Custom BME Aluminum connecting rods
Knife edged and lightened LS crank
ARP mainstuds
O-ringed
-- Custom AA Race cylinder head
Supertech valvetrain
custom grind cams
JG intake manifold w/ custom lower fuel rail
8-1600cc injectors
Kinsler mechanical fuel pump
Twin-12 rails
Borgwarner SC-72
AA custom made front mount turbo manifold
AA custom 3.5" charge pipe and WG dump
custom fuel cell
Kinsler K140 FPR
2 more fuel injectors on the lower IC piping for cooling
There is a lot I'm forgetting.
Running 100% Methanol
All tuned on AEM EMS
On one set of injectors - 700whp
When I switched to both sets of injectors and the car would jump and spin on the dyno. It was looking like ~1000whp on the second set.
Mods:
ARP mainstuds
O-ringed
custom grind cams
8-1600cc injectors
Twin-12 rails
Borgwarner SC-72
custom fuel cell
Kinsler K140 FPR
Here is a video of it from when I got it running.
http://www.addictsracing.com/fire-breathing-type-r
Looks real good, nice job on the 2-tone paint alot of people get the transition line wrong. Damn your running 10 Injectors too, some serious stuff you got going on there.
Looks like on OG PY car to me you can see where 2 brackets were removed in the bay and they are not painted underneath
Moves around abunch on the dyno. Adding anchors to the front of the dyno and crossing the straps will make it alittle safer. Big Horsepower is hard to control anyways but this will help
but what do you use for harnesses when you race? Those Takatas aren't SFI apporved
looks good
