Brake Master Cylinder Not Pumping Fluid!!! Need Help
Ok so like the title says, but heres a little bit of history. Im doing an ABS delete and i got everything i need, and im using a NEW Integra RS Brake Master Cylinder with my stock Integra SE Brake Booster. Well i hooked everything up and NO FLUID PUMPS OUT of the MC, I even dissconnected the lines to see if they come out off them and nothing!! I need all the help i can get Thanks in advanced.
Update: Ok so i removed the MC and had the lines hooked up to it and i hand pumped it and there was fluid pumping out so the MC is good. Why is it not doing it when its on the BB?? Do i need an RS BB??
do you see any leaks around the mc? is both booster and master working properly? is the rod present?
i know its a bit silly to ask but just covering basics.....
92integraVTECgsr
Oct 29, 2005 06:48 PM
